Eclipse Community ForumsEclipse RAP and EMF tools
https://www.eclipse.org/forums/index.php/mv/msg/1101026/1816116/#msg_1816116
If I install Eclipse IDE for RCP and RAP, and if after I install the plugins for EMF modelling capabilities, and if I load a project containing EMF models it's impossible after exit to reload Eclipse I have the following log:
This is a continuation of log file D:\Tony\Travail\LABO_RAP\SpotWorkspace\.metadata\.bak_0.log
Created Time: 2019-10-21 13:59:12.284
!ENTRY org.eclipse.oomph.p2.core 4 0 2019-10-21 13:59:12.284
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.oomph.p2.internal.core.P2CorePlugin$Implementation.stop() of bundle org.eclipse.oomph.p2.core.
at org.eclipse.osgi.internal.framework.BundleContextImpl.stop(BundleContextImpl.java:919)
at org.eclipse.osgi.internal.framework.EquinoxBundle.stopWorker0(EquinoxBundle.java:1029)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.stopWorker(EquinoxBundle.java:370)
at org.eclipse.osgi.container.Module.doStop(Module.java:658)
at org.eclipse.osgi.container.Module.stop(Module.java:520)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.decStartLevel(ModuleContainer.java:1885)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1760)
at org.eclipse.osgi.container.SystemModule.stopWorker(SystemModule.java:275)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule.stopWorker(EquinoxBundle.java:202)
Do you know why? It's very anoying because I am oblige to have two session of Eclipse open, one for RAP second for EMF
Thnaks a lot for your help
Antonio
]]>antonio guillen2019-10-21T13:12:00-00:00Re: Eclipse RAP and EMF tools
https://www.eclipse.org/forums/index.php/mv/msg/1101026/1816124/#msg_1816124
at the first quick look I see only p2 and Oomph in your stacktrace.
Based on that it is probably better to ask on their forum first, e.g. the Oomph forum can be found at [1], and they are typically very helpful.
Thanks and regards,
Markus]]>Markus Knauer2019-10-21T14:45:40-00:00Re: Eclipse RAP and EMF tools
https://www.eclipse.org/forums/index.php/mv/msg/1101026/1816125/#msg_1816125
In the next log you will see that the pb comme from EMF/sirius.... This run was before the previous one....
Created Time: 2019-10-20 23:25:57.031
!ENTRY org.eclipse.core.runtime 4 0 2019-10-20 23:25:57.033
!MESSAGE Invalid input url:platform:/plugin/org.eclipse.sirius.ui.editor/icons/SiriusFile.gif
!STACK 0
java.io.IOException: Unable to resolve plug-in "org.eclipse.sirius.ui.editor".
at org.eclipse.core.internal.runtime.PlatformURLPluginConnection.parse(PlatformURLPluginConnection.java:64)
at org.eclipse.core.internal.runtime.FindSupport.find(FindSupport.java:293)
at org.eclipse.core.runtime.FileLocator.find(FileLocator.java:206)
at org.eclipse.jface.resource.URLImageDescriptor.getStream(URLImageDescriptor.java:155)
at org.eclipse.jface.resource.URLImageDescriptor.getImageData(URLImageDescriptor.java:123)
at org.eclipse.jface.resource.URLImageDescriptor.access$3(URLImageDescriptor.java:121)
at org.eclipse.jface.resource.URLImageDescriptor$URLImageDataProvider.getImageData(URLImageDescriptor.java:77)
at org.eclipse.swt.internal.DPIUtil.validateAndGetImageDataAtZoom(DPIUtil.java:404)
at org.eclipse.swt.graphics.Image.<init>(Image.java:732)
at org.eclipse.jface.resource.URLImageDescriptor.createImage(URLImageDescriptor.java:271)
at org.eclipse.jface.resource.ImageDescriptor.createResource(ImageDescriptor.java:182)]]>antonio guillen2019-10-21T15:21:48-00:00
