Eclipse Community ForumsContinue debugging from failed break-point in eclipse
https://www.eclipse.org/forums/index.php/mv/msg/1100291/1811118/#msg_1811118
Eg: If i kept any breakpoints and any line of code, starting the debugging process from initial point of method, then if script got an issue an break-point, script is getting failed and again we need to start debugging process from initial point which takes more time.
So do we have any other solution like, debugging can be continue from the same break-point if any validation is failed as web page should be in sync with the eclipse.
This same feature is available in other automation tools like, Coded UI and test complete. As we can keep web application manually at specific point and debugging can be continue from that page itself.
Help me out if you any solutions.
