Eclipse Community ForumsFile dirty recognition
https://www.eclipse.org/forums/index.php/mv/msg/1100280/1811074/#msg_1811074
Jonathan Gossage2019-08-26T14:14:25-00:00Re: File dirty recognition
https://www.eclipse.org/forums/index.php/mv/msg/1100280/1811077/#msg_1811077
Is this file residing in an Eclipse project ?
Can you retry with JGit/EGit 5.4.2 [1] or latest build from master [2]?
[1] https://download.eclipse.org/egit/updates
[2] https://download.eclipse.org/egit/updates-nightly
]]>Matthias Sohn2019-08-26T14:31:49-00:00Re: File dirty recognition
https://www.eclipse.org/forums/index.php/mv/msg/1100280/1811094/#msg_1811094
Jonathan Gossage2019-08-26T18:30:52-00:00Re: File dirty recognition
https://www.eclipse.org/forums/index.php/mv/msg/1100280/1811100/#msg_1811100
Jonathan Gossage2019-08-26T22:58:58-00:00Re: File dirty recognition
https://www.eclipse.org/forums/index.php/mv/msg/1100280/1811105/#msg_1811105
Alternatively you can use Help -> Install New Software. Paste an update site there. There is a "Hide items that are already installed", so to do an update, you'd have to uncheck that to be able to update something you've already installed; the processing will turn this into an update request if you "install" something that is already installed.
]]>Ed Merks2019-08-27T04:34:35-00:00Re: File dirty recognition
https://www.eclipse.org/forums/index.php/mv/msg/1100280/1811117/#msg_1811117
Jonathan Gossage2019-08-27T06:59:16-00:00Re: File dirty recognition
https://www.eclipse.org/forums/index.php/mv/msg/1100280/1811140/#msg_1811140
Jonathan Gossage2019-08-27T13:03:38-00:00Re: File dirty recognition
https://www.eclipse.org/forums/index.php/mv/msg/1100280/1811141/#msg_1811141
Jonathan Gossage2019-08-27T13:05:57-00:00Re: File dirty recognition
https://www.eclipse.org/forums/index.php/mv/msg/1100280/1811142/#msg_1811142
Jonathan Gossage2019-08-27T13:17:36-00:00Re: File dirty recognition
https://www.eclipse.org/forums/index.php/mv/msg/1100280/1811271/#msg_1811271
Note that [2] is a temporary update site which will be removed after final 5.5.0 has been released on Sept 19.
