Eclipse Community Forumseclipse available to all users
https://www.eclipse.org/forums/index.php/mv/msg/1099579/1808872/#msg_1808872
I get error:
"The Eclipse executable launcher was unable to locate its companion shared library."
Any suggestions?]]>toffer 962019-07-03T15:48:55-00:00Re: eclipse available to all users
https://www.eclipse.org/forums/index.php/mv/msg/1099579/1808888/#msg_1808888
If you're using the installer you should keep in mind that by default it uses a shared bundle pool which by default is in the user's home folder (so could end up in the admin's home folder of whatever home you were in before assuming admin privileges. If you want to use the installer to created a so-called shared installation you will need to think more carefully about where to locate the bundle pool (or disable the bundle pool option), both of which you can control via the installer's menu. Then it's important that both the folder containing the installation and the folder containing the pool be visible but read-only to the domain user.]]>Ed Merks2019-07-04T04:11:54-00:00
