Eclipse Community ForumsCAsn1Layer:: serializeData Failed
https://www.eclipse.org/forums/index.php/mv/msg/1098308/1804856/#msg_1804856
i'm using multiple PUBLISH_6 when trying to send value from FORTE_1 to FORTE_2. But get stuck with this error. CASn1Layer:: serializeData Failed.
Anyone could help, please?
Thank you so much for anyone help.
Sincerely,
Stefanus Yudi Irwan]]>Stefanus Yudi2019-04-02T12:41:39-00:00Re: CAsn1Layer:: serializeData Failed
https://www.eclipse.org/forums/index.php/mv/msg/1098308/1804857/#msg_1804857
Stefanus Yudi2019-04-02T12:49:40-00:00Re: CAsn1Layer:: serializeData Failed
https://www.eclipse.org/forums/index.php/mv/msg/1098308/1804876/#msg_1804876
https://wiki.eclipse.org/Google_Summer_of_Code_2019_Ideas#Eclipse_4diac]]>Alois Zoitl2019-04-02T15:56:41-00:00Re: CAsn1Layer:: serializeData Failed
https://www.eclipse.org/forums/index.php/mv/msg/1098308/1852807/#msg_1852807
I also got the CAsn1Layer:: serializeData failed, but in my case I'm using the Publish_1, Subscribe_1 FBs.
After several tests it seems that the error is related to the amount of FBs: Up to two is ok, more than that serializeData failed.
In this App I'm using FORTE and 4diac IDE v2.0.0 and the FBs are split into localhost:61499 (blink) and localhost:61500 (counter).
Using multicast UDP at 239.0.0.1 and ports 61000, 61001 and 61002, as the image below.
Does someone have any idea how to fix it?
]]>Ricardo Rech2022-06-04T23:18:23-00:00Re: CAsn1Layer:: serializeData Failed
https://www.eclipse.org/forums/index.php/mv/msg/1098308/1852823/#msg_1852823
can you show us the FB Network in your 61499 resource?
