Eclipse Community ForumsRAP-Application on Glassfish
https://www.eclipse.org/forums/index.php/mv/msg/1098203/1804465/#msg_1804465
I'm very new to the topics RAP and RCP. My task is it to implement a RAP-Application which should run on a Glassfish server 4.0.
My problem is that it doesn't run on the glassfish. I created a new plug-in project with the rap e4 demo. In eclipse the application runs. Then I tried to convert it to a maven project and deploy it on glassfish. But I always get an error message.
Thanks for your help,
Markus ]]>Markus Sundermann2019-03-26T12:16:25-00:00Re: RAP-Application on Glassfish
https://www.eclipse.org/forums/index.php/mv/msg/1098203/1804505/#msg_1804505
Markus Sundermann2019-03-27T14:17:52-00:00Re: RAP-Application on Glassfish
https://www.eclipse.org/forums/index.php/mv/msg/1098203/1804515/#msg_1804515
You've provide almost no information about your specific problem, so I don't know how anyone can be expected to help you.]]>Chris Fairhall2019-03-27T19:28:48-00:00Re: RAP-Application on Glassfish
https://www.eclipse.org/forums/index.php/mv/msg/1098203/1804520/#msg_1804520
thank you for the answer.
I use the Eclipse ID for RCP (Version: 2019-03 (4.11.0) Build id: 20190314-1200) and RAP-Developers and the GlassFish Server Open Source Edition 4.0 (build 89).
I've tried it with the WAR Product Configuration and with this guide :
Then I deployed the war-archive on GlassFish and launched. The error message I've got is:
HTTP Status 404 - BridgeServlet: /rapdemo/workbench/ type
Status report messageBridgeServlet: /rapdemo/workbench/ description
The requested resource is not available. GlassFish Server Open Source Edition 4.0
In the Log of the Glassfish I get a lot of "ArrayIndexOutOfBoundsException"-Exceptions.
Thanks for the help!]]>Markus Sundermann2019-03-28T07:00:44-00:00Re: RAP-Application on Glassfish
https://www.eclipse.org/forums/index.php/mv/msg/1098203/1804792/#msg_1804792
which RAP version are you using. We discovered a problem in Equinox that prevents RAP applications built on RAP 3.8 to start on servlet container based on Servlet 3.1 Spec [1]. There is a workaround of the problem to manually create and add to the war file "org.eclipse.equinox.servletbridge.extensionbundle" bundle that re-exports "javax.sevlet" as 3.1.
