Eclipse Community ForumsWhat are the limitations?
https://www.eclipse.org/forums/index.php/mv/msg/1097747/1803090/#msg_1803090
we're currently planning to use Kapua in a growing environment. Are there any limitations to Kapua - i.e. simultanious connections, maximum devices and/or users - we might hit in the future or are the only limits set by the power of the server?]]>Florian Otto2019-02-22T09:12:29-00:00Re: What are the limitations?
https://www.eclipse.org/forums/index.php/mv/msg/1097747/1804276/#msg_1804276
Gambit Support2019-03-21T17:03:41-00:00Re: What are the limitations?
https://www.eclipse.org/forums/index.php/mv/msg/1097747/1804329/#msg_1804329
Now, the challenge is to figure out the device protocol, which is not documented anywhere.]]>Gambit Support2019-03-22T13:37:29-00:00Re: What are the limitations?
https://www.eclipse.org/forums/index.php/mv/msg/1097747/1804342/#msg_1804342
Screenshot attached.]]>Gambit Support2019-03-22T17:11:25-00:00Re: What are the limitations?
https://www.eclipse.org/forums/index.php/mv/msg/1097747/1808770/#msg_1808770
there is no limits at code level for the connections. There is a limit for the registered devices for an account (both connected and disconnected one).
In which form you encounter a limit?
- Alberto]]>Alberto Codutti2019-07-01T10:35:53-00:00Re: What are the limitations?
https://www.eclipse.org/forums/index.php/mv/msg/1097747/1817553/#msg_1817553
do you mean that the limit for the registered devices for an account is at code level?
Or you talk about the DeviceRegistryService configuration ?
]]>Federico Cerruto2019-11-25T17:29:48-00:00
