Eclipse Community Forumswinsock2.h error when build FORTE
https://www.eclipse.org/forums/index.php/mv/msg/1097118/1801333/#msg_1801333
i have read the instruction on https://www.eclipse.org/4diac/en_help.php?helppage=html/communication/opc_ua.html about configuring forte, and follow step by step in Windows with Visual Studio part. Acctually i'm using VS 2015 Community edition right now.
But at step 15 i got stuck with error, i attach with this post.
Is there anyone could help me solve this error?
Many thanks]]>Stefanus Yudi2019-01-17T05:00:53-00:00Re: winsock2.h error when build FORTE
https://www.eclipse.org/forums/index.php/mv/msg/1097118/1801350/#msg_1801350
try to undefine IN in the opcua_handler. Some windows header add the preprocessor symbols IN and OUT, which can clash with FORTE code.
Martin]]>Martin Melik Merkumians2019-01-17T11:03:30-00:00Re: winsock2.h error when build FORTE
https://www.eclipse.org/forums/index.php/mv/msg/1097118/1804788/#msg_1804788
Alois Zoitl2019-04-01T09:35:28-00:00Re: winsock2.h error when build FORTE
https://www.eclipse.org/forums/index.php/mv/msg/1097118/1804974/#msg_1804974
Jose Maria Jesus Cabral Lassalle2019-04-04T07:11:40-00:00Re: winsock2.h error when build FORTE
https://www.eclipse.org/forums/index.php/mv/msg/1097118/1805002/#msg_1805002
Alois Zoitl2019-04-04T12:52:59-00:00Re: winsock2.h error when build FORTE
https://www.eclipse.org/forums/index.php/mv/msg/1097118/1816992/#msg_1816992
I have the same issue when building forte with open62541.
forte:
Revision: f435b4e3b34e2a240ef48e52f2c06cc890a5204c
Merge branch '1.11.x' for 1.11.0 release
open62541:
Revision: 280012ee016e2f42ab9b1386174a8c12e6b29821
Message:
Included plugin/log.h cleanup in UA_Client_delete(..).
