Creation of ESH-Event failed, because one of the registered event factories has thrown an exception: Error getting class for simple name: 'XyzType' using package name 'org.eclipse.smarthome.core.library.types.'.
at org.eclipse.smarthome.core.items.events.ItemEventFactory.parseSimpleClassName(ItemEventFactory.java:183) ~[?:?] at org.eclipse.smarthome.core.items.events.ItemEventFactory.parseType(ItemEventFactory.java:158) ~[?:?] at org.eclipse.smarthome.core.items.events.ItemEventFactory.getState(ItemEventFactory.java:136) ~[?:?] at org.eclipse.smarthome.core.items.events.ItemEventFactory.createStateEvent(ItemEventFactory.java:116) ~[?:?] at org.eclipse.smarthome.core.items.events.ItemEventFactory.createEventByType(ItemEventFactory.java:80) ~[?:?] at org.eclipse.smarthome.core.events.AbstractEventFactory.createEvent(AbstractEventFactory.java:51) ~[?:?] at org.eclipse.smarthome.core.internal.events.EventHandler.createESHEvent(EventHandler.java:121) ~[?:?] at org.eclipse.smarthome.core.internal.events.EventHandler.handleEvent(EventHandler.java:95) ~[?:?] at org.eclipse.smarthome.core.internal.events.EventHandler.handleEvent(EventHandler.java:72) ~[?:?] at org.eclipse.smarthome.core.internal.events.ThreadedEventHandler.lambda$0(ThreadedEventHandler.java:67) ~[?:?] at java.lang.Thread.run(Thread.java:748) [?:?] Caused by: java.lang.ClassNotFoundException: org.eclipse.smarthome.core.library.types.XyzType cannot be found by org.eclipse.smarthome.core_0.10.0 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:484) ~[?:?] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[?:?] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[?:?] at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[?:?] at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:?] at java.lang.Class.forName0(Native Method) ~[?:?] at java.lang.Class.forName(Class.java:264) ~[?:?] at org.eclipse.smarthome.core.items.events.ItemEventFactory.parseSimpleClassName(ItemEventFactory.java:179) ~[?:?] ... 10 more
if ("toggle".equalsIgnoreCase(value) && (item instanceof SwitchItem || item instanceof RollershutterItem)) { if (OnOffType.ON.equals(item.getStateAs(OnOffType.class))) { command = OnOffType.OFF; } if (OnOffType.OFF.equals(item.getStateAs(OnOffType.class))) { command = OnOffType.ON; } if (UpDownType.UP.equals(item.getStateAs(UpDownType.class))) { command = UpDownType.DOWN; } if (UpDownType.DOWN.equals(item.getStateAs(UpDownType.class))) { command = UpDownType.UP; } } else { command = TypeParser.parseCommand(item.getAcceptedCommandTypes(), value); }
