Eclipse Community ForumsInitialize papyrus diagram
https://www.eclipse.org/forums/index.php/mv/msg/1096586/1799632/#msg_1799632
I have a existing ".uml" model.
When right clicking on it there is no "Initialize papyrus diagram" menu.
How can I initialize an existing uml model with Papyrus?]]>Pieter Martin2018-12-11T16:53:25-00:00Re: Initialize papyrus diagram
https://www.eclipse.org/forums/index.php/mv/msg/1096586/1799634/#msg_1799634
Just launch the usual "New Papyrus Model" wizard and it will see that you already have an UML resource. It will not create a new model but will use the existing one, adding the *.di and *.notation files to it.
HTH,
Christian]]>Christian Damus2018-12-11T17:03:05-00:00Re: Initialize papyrus diagram
https://www.eclipse.org/forums/index.php/mv/msg/1096586/1799635/#msg_1799635
Try it with a test "*..uml" first.
And before trying on your "*.uml" model back it up first to prevent any mishaps.]]>Adriano Carvalho2018-12-11T17:07:45-00:00Re: Initialize papyrus diagram
https://www.eclipse.org/forums/index.php/mv/msg/1096586/1799639/#msg_1799639
The first time it deleted my model creating a new one.
The trick is too not specify a root model name, then it will use the existing model.]]>Pieter Martin2018-12-11T18:32:19-00:00Re: Initialize papyrus diagram
https://www.eclipse.org/forums/index.php/mv/msg/1096586/1799645/#msg_1799645
https://bugs.eclipse.org/bugs/enter_bug.cgi?component=Core&product=Papyrus&version=4.1.0
