Eclipse Community ForumsOSGi test problem: missing constraints
https://www.eclipse.org/forums/index.php/mv/msg/1096114/1798002/#msg_1798002
I just added an OSGi test to my new Time Condition, but when I try to run the test configuration in org.eclipse.smarthome.automation.module.timer.test it gives me the message that theres a missing constraint. One of these is the import package org.eclipse.smarthome.test. When I add this package to the run configuration plug ins I get even more missing constraints.
Can anyone tell me what I am doing wrong?]]>Dominik Schlierf2018-11-09T23:21:57-00:00Re: OSGi test problem: missing constraints
https://www.eclipse.org/forums/index.php/mv/msg/1096114/1798098/#msg_1798098
the launch configs sometimes get outdated so the process you already started is the way to go: Add org.eclipse.smarthome.test to the import packages and you probably have to add javax.servlet along with some jetty packages. You are welcome to also contribute the updated launch config with your PR.
