Eclipse Community ForumsProject context menu item "Run As" missing...
https://www.eclipse.org/forums/index.php/mv/msg/1095053/1794864/#msg_1794864
This morning I noticed that the project context menu (mouse right button) item "Run As" is missing. Also "Debug As" and "Coverage As" are missing. See the attached image. However, they exist in main menu under "Run".
This concerns both the Java projects (Run As > Java Application) and Dynamic Web Projects (Run As > Run on Server).
I created a new work space and also tried to start with an option "-clean".
Has anyone had this problem lately? What could cause the problem?
Harri
]]>Harri T.2018-09-09T10:59:27-00:00Re: Project context menu item "Run As" missing...
https://www.eclipse.org/forums/index.php/mv/msg/1095053/1794865/#msg_1794865
Ed Merks2018-09-09T13:53:17-00:00
