hierarchyHandling: INCLUDE_CHILDREN node parent { portConstraints: FIXED_SIDE port W1 { ^port.side: WEST } port S1 { ^port.side: SOUTH } port S2 { ^port.side: SOUTH } node child { port P node innermost } edge W1 -> child.P }
.setProperty(CoreOptions.ALGORITHM, "org.eclipse.elk.alg.layered") .setProperty(CoreOptions.DIRECTION, Direction.RIGHT) .setProperty(CoreOptions.PORT_LABELS_PLACEMENT, PortLabelPlacement.INSIDE) .setProperty(LayeredOptions.PORT_CONSTRAINTS, PortConstraints.FIXED_SIDE) .setProperty(CoreOptions.NODE_SIZE_OPTIONS, EnumSet.of(SizeOptions.MINIMUM_SIZE_ACCOUNTS_FOR_PADDING)) .setProperty(CoreOptions.NODE_SIZE_CONSTRAINTS, EnumSet.allOf(SizeConstraint.class)) .setProperty(CoreOptions.NODE_LABELS_PLACEMENT, NodeLabelPlacement.insideTopCenter()) .setProperty(LayeredOptions.MERGE_EDGES, true).setProperty(LayeredOptions.MERGE_HIERARCHY_EDGES, true) .setProperty(CoreOptions.HIERARCHY_HANDLING, HierarchyHandling.INCLUDE_CHILDREN);
java.lang.NullPointerException at org.eclipse.elk.alg.layered.p3order.AbstractBarycenterPortDistributor.updateNodePositions(AbstractBarycenterPortDistributor.java:325) at org.eclipse.elk.alg.layered.p3order.AbstractBarycenterPortDistributor.distributePortsWhileSweeping(AbstractBarycenterPortDistributor.java:85) at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.sweepReducingCrossings(LayerSweepCrossingMinimizer.java:248) at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.sweepInHierarchicalNode(LayerSweepCrossingMinimizer.java:287) at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.sweepInHierarchicalNodes(LayerSweepCrossingMinimizer.java:266) at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.sweepReducingCrossings(LayerSweepCrossingMinimizer.java:250) at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.minimizeCrossingsWithCounter(LayerSweepCrossingMinimizer.java:200) at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.compareDifferentRandomizedLayouts(LayerSweepCrossingMinimizer.java:185) at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.lambda$1(LayerSweepCrossingMinimizer.java:131) at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.minimizeCrossings(LayerSweepCrossingMinimizer.java:143) at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.process(LayerSweepCrossingMinimizer.java:121) at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.process(LayerSweepCrossingMinimizer.java:1) at org.eclipse.elk.alg.layered.ElkLayered.hierarchicalLayout(ElkLayered.java:241) at org.eclipse.elk.alg.layered.ElkLayered.doCompoundLayout(ElkLayered.java:182) at org.eclipse.elk.alg.layered.LayeredLayoutProvider.layout(LayeredLayoutProvider.java:58) at org.eclipse.elk.core.RecursiveGraphLayoutEngine.executeAlgorithm(RecursiveGraphLayoutEngine.java:222) at org.eclipse.elk.core.RecursiveGraphLayoutEngine.layoutRecursively(RecursiveGraphLayoutEngine.java:197) at org.eclipse.elk.core.RecursiveGraphLayoutEngine.layout(RecursiveGraphLayoutEngine.java:76) at org.eclipse.elk.core.service.DiagramLayoutEngine.layout(DiagramLayoutEngine.java:718) at org.eclipse.elk.core.service.DiagramLayoutEngine.layout(DiagramLayoutEngine.java:650) at org.eclipse.elk.core.service.DiagramLayoutEngine$1.execute(DiagramLayoutEngine.java:400) at org.eclipse.elk.core.service.util.MonitoredOperation$1.run(MonitoredOperation.java:236) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:748)
