Eclipse Community ForumsError can't find main class
https://www.eclipse.org/forums/index.php/mv/msg/1092668/1785003/#msg_1785003
I just started coding with java and am having errors with eclipse not being able to find the main class and its not recognizing the jdk standard library.
I cannot run my code at all. No matter what code I try to run it will always return the error that it can't find the main class. I'm using java 10.]]>Sarah Minzer2018-04-06T19:46:51-00:00Re: Error can't find main class
https://www.eclipse.org/forums/index.php/mv/msg/1092668/1785228/#msg_1785228
Ed Merks2018-04-11T08:51:53-00:00
