Eclipse Community ForumsAssociation between metaclass and stereotype
https://www.eclipse.org/forums/index.php/mv/msg/1092135/1783141/#msg_1783141
i want to link the metaclass relationship with the stereotype requirement with an association
and even the metaclass with the stereotype derivereq and contains with generalization but i can't do it i don't know why !!]]>Emilie Lanau2018-03-08T13:14:56-00:00Re: Association between metaclass and stereotype
https://www.eclipse.org/forums/index.php/mv/msg/1092135/1783143/#msg_1783143
It seems that Requirement is an imported element. This probably means that it is read-only, thus you can't add a new association on that element (Although it might be possible to actually create that association, if both members ends are "owned by association". But I don't think you can create such an association from the Profile Diagram)
You may try to make the Requirement explicitly writable (On the Requirement stereotype: right click > Enable write), then create the association.
Camille]]>Camille Letavernier2018-03-08T13:27:03-00:00Re: Association between metaclass and stereotype
https://www.eclipse.org/forums/index.php/mv/msg/1092135/1783156/#msg_1783156
You want to specialize Requirement and it links.
Why do you want to add an association between requirement and metaClass?
When you add an association between Requirement and a metclass you modify these elements by adding association ends in Requirement or Metaclass. You cannot modify SYML profile or metamodel of UML.
So if you want ot add a relation of Requirement to a metaclass. Create a specialization of Requirement and link it to the metaclass.]]>Patrick Tessier2018-03-08T15:18:42-00:00
