as promised (https://www.eclipse.org/forums/index.php/t/1091853/), we will look into compiling the ETSI IPV6 test suite
( available here http://www.ttcn-3.org/index.php/downloads/publicts/publicts-etsi/25-publicts-ipv6)
with Titan.
I will do this step by step, analyzing the errors encountered; it's probably a boring read unless you download the code yourself and
closely follow. Impatient readers can skip this and go straight to the attached package which is compilable; but not functional, for the reasons I will explain below.
The compiler used is the binary built from the latest source.
The output of the exercise will be a bunch of code that compiles , but will not execute, for the following reasons:
as explained in https://www.eclipse.org/forums/index.php/t/1087046/ , large areas of a TTCN-3 code are not standardized,
namely external functions, test ports and codec, so when migrating from one tool to another these will have to be adjusted.
OK so after downloading and unzipping the compressed package , this is the resulting directory structure:
tree
|-- EtsiAts
| `-- AtsIpv6
| |-- AtsCommon
| | |-- AtsIpv6_Common_Functions.ttcn
| | |-- AtsIpv6_Defaults.ttcn
| | |-- AtsIpv6_ModuleParameters.ttcn
| | |-- AtsIpv6_Postambles.ttcn
| | |-- AtsIpv6_Preambles.ttcn
| | |-- AtsIpv6_TestConfiguration.ttcn
| | |-- AtsIpv6_TestConfiguration_TypesAndValues.ttcn
| | `-- AtsIpv6_TestSystem.ttcn
| `-- AtsCore
| |-- AtsIpv6_Core_TestControl.ttcn
| |-- AtsIpv6_Core_Tp_Functions.ttcn
| |-- AtsIpv6_GenerateIpv6Packets_Testcases.ttcn
| |-- AtsIpv6_Icmpv6Functions_Testcases.ttcn
| |-- AtsIpv6_Initialize_Testcases.ttcn
| |-- AtsIpv6_Jumbograms_Testcases.ttcn
| |-- AtsIpv6_NeighborDiscovery_Testcases.ttcn
| `-- AtsIpv6_ProcessIpv6Packets_Testcases.ttcn
|-- EtsiLibrary
| |-- LibCommon
| | |-- LibCommon_AbstractData.ttcn
| | |-- LibCommon_BasicTypesAndValues.ttcn
| | |-- LibCommon_DataStrings.ttcn
| | |-- LibCommon_Sync.ttcn
| | |-- LibCommon_SyncExamples.ttcn
| | |-- LibCommon_TextStrings.ttcn
| | |-- LibCommon_Time.ttcn
| | `-- LibCommon_VerdictControl.ttcn
| |-- LibIpv6
| | |-- LibCommonRfcs
| | | |-- LibIpv6_CommonRfcs_Functions.ttcn
| | | |-- LibIpv6_CommonRfcs_Templates.ttcn
| | | |-- LibIpv6_CommonRfcs_TypesAndValues.ttcn
| | | |-- LibIpv6_ExternalFunctions.ttcn
| | | |-- LibIpv6_Interface_Functions.ttcn
| | | |-- LibIpv6_Interface_Templates.ttcn
| | | |-- LibIpv6_Interface_TypesAndValues.ttcn
| | | `-- LibIpv6_ModuleParameters.ttcn
| | |-- LibCore
| | | |-- LibIpv6_Rfc2461NeighborDiscovery_Functions.ttcn
| | | |-- LibIpv6_Rfc2461NeighborDiscovery_Templates.ttcn
| | | |-- LibIpv6_Rfc2461NeighborDiscovery_TypesAndValues.ttcn
| | | |-- LibIpv6_Rfc2462StatelessAddressAutoconf_Functions.ttcn
| | | |-- LibIpv6_Rfc2462StatelessAddressAutoconf_Templates.ttcn
| | | |-- LibIpv6_Rfc2462StatelessAddressAutoconf_TypesAndValues.ttcn
| | | |-- LibIpv6_Rfc2463Icmpv6_Functions.ttcn
| | | |-- LibIpv6_Rfc2463Icmpv6_Templates.ttcn
| | | |-- LibIpv6_Rfc2463Icmpv6_TypesAndValues.ttcn
| | | |-- LibIpv6_Rfc2894RouterRenumbering_Functions.ttcn
| | | `-- LibIpv6_Rfc2894RouterRenumbering_TypesAndValues.ttcn
| | |-- LibMobility
| | | |-- LibIpv6_Rfc3775Mipv6_Functions.ttcn
| | | |-- LibIpv6_Rfc3775Mipv6_Templates.ttcn
| | | |-- LibIpv6_Rfc3775Mipv6_TypesAndValues.ttcn
| | | |-- LibIpv6_Rfc4068FastHandovers_Functions.ttcn
| | | |-- LibIpv6_Rfc4068FastHandovers_Templates.ttcn
| | | `-- LibIpv6_Rfc4068FastHandovers_TypesAndValues.ttcn
| | |-- LibMultiRfcs
| | | `-- LibIpv6_MultiRfcs_Functions.ttcn
| | |-- LibSec
| | | |-- LibIpv6_Rfc4306Ikev2_Functions.ttcn
| | | |-- LibIpv6_Rfc4306Ikev2_Templates.ttcn
| | | `-- LibIpv6_Rfc4306Ikev2_TypesAndValues.ttcn
| | |-- LibTransitioning
| | | |-- LibIpv6_CommonTrans_Functions.ttcn
| | | |-- LibIpv6_Rfc792Icmpv4_Functions.ttcn
| | | |-- LibIpv6_Rfc792Icmpv4_Templates.ttcn
| | | |-- LibIpv6_Rfc792Icmpv4_TypesAndValues.ttcn
| | | |-- LibIpv6_Rfc826Arp_Functions.ttcn
| | | |-- LibIpv6_Rfc826Arp_Templates.ttcn
| | | `-- LibIpv6_Rfc826Arp_TypesAndValues.ttcn
| | `-- LibUdp
| | |-- LibIpv6_Rfc0768Udp_Templates.ttcn
| | `-- LibIpv6_Rfc0768Udp_TypesAndValues.ttcn
| `-- LibScop
| |-- LibScop_Codec.ttcn
| |-- LibScop_CodecTests.ttcn
| |-- LibScop_Functions.ttcn
| |-- LibScop_Interface.ttcn
| |-- LibScop_Templates.ttcn
| `-- LibScop_TypesAndValues.ttcn
As there is an import hierarchy , I will start from the bottom, with LibCommon. I have created a separate directory bin, where I will create symlinks using a script install.script As I advance, I will add more files to this script and regenerate the Makefile with makefilegen -f *.ttcn ;
I will also add -w to the compiler flags to obscure warnings;
The first script is:
#!/bin/bash
ln -s ../EtsiLibrary/LibCommon/LibCommon_AbstractData.ttcn .
ln -s ../EtsiLibrary/LibCommon/LibCommon_BasicTypesAndValues.ttcn .
ln -s ../EtsiLibrary/LibCommon/LibCommon_DataStrings.ttcn .
ln -s ../EtsiLibrary/LibCommon/LibCommon_SyncExamples.ttcn .
ln -s ../EtsiLibrary/LibCommon/LibCommon_Sync.ttcn .
ln -s ../EtsiLibrary/LibCommon/LibCommon_TextStrings.ttcn .
ln -s ../EtsiLibrary/LibCommon/LibCommon_Time.ttcn .
ln -s ../EtsiLibrary/LibCommon/LibCommon_VerdictControl.ttcn .
this will be run from bin:
a Makefile will be generated:
and then a compilation is attempted with
there will be a bunch of errors displayed;
1. the first one is :
LibCommon_Sync.ttcn: In TTCN-3 module `LibCommon_Sync':
LibCommon_Sync.ttcn:163.4-170.4: In function definition `f_connect4SelfOrClientSync':
LibCommon_Sync.ttcn:167.7-169.5: In else statement:
LibCommon_Sync.ttcn:168.6-27: In function instance:
LibCommon_Sync.ttcn:168.6-27: error: Runs on clause mismatch: A definition that runs on component type `@LibCommon_Sync.SelfSyncComp' cannot call function `@LibCommon_Sync.f_connect4ClientSync', which runs on `@LibCommon_Sync.ClientSyncComp'
followed by others similar.
The error sheds light on one of the idiosynchrasies of Titan:
although the standard defines an implicit component type compatibility, Titan does not support this:
In LibCommon_Sync.ttcn
type component ClientSyncComp {
var StringStack v_stateStack:= c_initStringStack;
port SyncPort syncPort;
timer tc_sync := PX_TSYNC_TIME_LIMIT;
type component SelfSyncComp {
port SyncPort syncSendPort;
component ClientSyncComp should be compatible with SelfSyncComp, but Titan expects an explicit declaration of compatibility, either in form
of a type alias (possible when the declarations on the two components are exactly the same) or in the form of component extension.
So to handle the error we have to declare SelfSyncComp as a child of ClientSyncComp:
type component SelfSyncComp extends ClientSyncComp {
// var StringStack v_stateStack:= c_initStringStack;
// port SyncPort syncPort;
// timer tc_sync := PX_TSYNC_TIME_LIMIT;
declarations already existing in ClientSyncComp declaration have been removed.
2. the next error is similar:
LibCommon_SyncExamples.ttcn: In TTCN-3 module `LibCommon_SyncExamples':
LibCommon_SyncExamples.ttcn:133.3-159.3: In testcase definition `tc_selfSyncOk':
LibCommon_SyncExamples.ttcn:137.16-51: In variable definition `v_def':
LibCommon_SyncExamples.ttcn:137.25-51: In `activate()' operation:
LibCommon_SyncExamples.ttcn:137.34-50: error: Runs on clause mismatch: A definition that runs on component type `@LibCommon_SyncExamples.ExampleComp' cannot activate altstep `@LibCommon_Sync.a_dummyShutDown', which runs on `@LibCommon_Sync.SelfSyncComp'
in LibCommon_SyncExamples
type component ExampleComp
// parts needed for Client/SelfSyncComp type compatibility
// here could follow additional port, variable,
// and timer definitions of any kind
has to be made explicitly compatible with LibCommon_Sync.SelfSyncComp
as the declarations are the same , we will use alias this time:
type SelfSyncComp ExampleComp; //alias
3. next error thrown is:
In file included from LibCommon_SyncExamples.hh:20:0,
from LibCommon_SyncExamples.cc:11:
LibCommon_Sync.hh:720:23: fatal error: SyncPort.hh: No such file or directory
compilation terminated.
Now what happens here is that Titan is looking for the C/C++ code of the test ports declared in the TTCN-3 code.
There are two categories of test ports : internal , which will connect two components, and external which will map a component to the system.
Internal ports ( declared "with {extension "internal"}" will not need external C/C++ code. I will make all port declarations internal
to permit compilation , but in the end those meant to be external will have to be written appropriate C/C++ code.
in LibCommon_Sync
type port SyncPort message { inout SyncCmd } with {extension "internal" };
Now LibCommon should compile.
We can move to the next step and add LibScop
#!/bin/bash
ln -s ../EtsiLibrary/LibScop/LibScop_CodecTests.ttcn .
ln -s ../EtsiLibrary/LibScop/LibScop_Codec.ttcn .
ln -s ../EtsiLibrary/LibScop/LibScop_Functions.ttcn .
ln -s ../EtsiLibrary/LibScop/LibScop_Interface.ttcn .
ln -s ../EtsiLibrary/LibScop/LibScop_Templates.ttcn .
ln -s ../EtsiLibrary/LibScop/LibScop_TypesAndValues.ttcn .
First error thrown:
LibScop_Codec.ttcn: In TTCN-3 module `LibScop_Codec':
LibScop_Codec.ttcn:26.5-59.2: In function definition `f_encodeScop':
LibScop_Codec.ttcn:29.3-33: In variable assignment:
LibScop_Codec.ttcn:29.15-33: In the operand of operation `str2oct()':
LibScop_Codec.ttcn:29.23-32: error: The operand of operation `str2oct()' can contain only valid hexadecimal digits (position 0 is `S')
in LibScop_Codec.ttcn
function f_encodeScop ( in ScopMsg p_scopMsg, out octetstring p_encMsg )
return FncRetCode {
var FncRetCode v_ret := e_success;
p_encMsg := char2oct("SCOP/1.0");
Now this is a misuse of the char2oct function, which according to the standard
C.1.28 Character string to octetstring
str2oct(in charstring invalue) return octetstring
This function converts a string of the type charstring to an octetstring. The string invalue shall contain the "0", "1", "2", "3", "4", "5", "6", "7", "8", "9", "a", "b", "c", "d", "e" "f", "A", "B", "C", "D", "E" or "F" graphical characters only.
The right function to use here is str2oct. After replacing char2oct with str2oct LibCommon and LIbScope compiles together.
Now there's a morale here: it appears that this test suite was never executed by ETSI , probably all they have done to verify it
was to compile it with a tool that possibly overlooked this fault.
To be continued.
Best regards
Elemer
