Eclipse Community Forumslabel taken from channel-type and not from overwritten channel definition
https://www.eclipse.org/forums/index.php/mv/msg/1091466/1781136/#msg_1781136
I'm developing a new binding.
I have a channel-type in channels.xml:
<channel-type id="switchTimes">
<item-type>String</item-type>
<label>Switch Time</label>
<description>Switch times of Mon-Sun format: "XX:XX-XX:XX XX:XX-XX:XX".</description>
<category>Radiator</category>
</channel-type>
Using simple Mode for Item binding The Items will be named with the correct Weekdays - but using manual binding the item name will contain SwitchTime.
As a start I'm looking for the point in the source code where the new Item name is prepared, because GenericItem gets created with the wrong name.]]>Arne Plöse2018-02-01T19:56:31-00:00Re: label taken from channel-type and not from overwritten channel definition
https://www.eclipse.org/forums/index.php/mv/msg/1091466/1781159/#msg_1781159
Simon Kaufmann2018-02-02T08:29:00-00:00Re: label taken from channel-type and not from overwritten channel definition
https://www.eclipse.org/forums/index.php/mv/msg/1091466/1781255/#msg_1781255
Make sure Configuration > System > Item Linking > Simple Mode is disabled.
1. In Configuration > Things > "ThingName" > "ChannelName" press the empty circle of said channel ("Tuesday").
2. In the dialogbox select "+Create new item".
3. In the now opened dialogbox "Link channel" the
name will be "FHT80b202_SwitchTime" and the
label will be "Switch Time".
If I had the channel with id="tuesdaySwitchTimes" I would expect to have as
name "FHT80b202_Tuesday" and as
label "Tuesday".
OK Im scanned the paperUI sources.
in /org.eclipse.smarthome.ui.paper/web-src/js/controllers/controller.things.view.js
in line 79: $scope.linkChannel = function(channelID, event, preSelect) {
In this function suggestedLabel is taken from the channeltype instead from the channel.
And the result of getItemNameSuggestion is also from channelType.]]>Arne Plöse2018-02-05T07:02:15-00:00
