Eclipse Community ForumsTrouble building projects the second time
https://www.eclipse.org/forums/index.php/mv/msg/1089469/1774533/#msg_1774533
I am using eclipse-cpp-oxygen-1-rc4-win32-x86_64, on a 64 bit windows 10 machine, with MinGW 64 bit compiler. I am new to using eclipse for C++. I am able to build my projects successfully for the first time. But after modifying my programs, I cannot build them the second time because I get the following error message:
"cannot open output file filename.exe: Permission denied
collect2.exe: error: ld returned 1 exit status"
Similar messages appears when I try to do Clean project. I cannot delete the exe files generated from the first build even after closing eclipse using the windows explorer.
I request the communities help in troubleshooting the issue.
Thanks.]]>Sanat Upadhyay2017-10-16T21:10:55-00:00Re: Trouble building projects the second time
https://www.eclipse.org/forums/index.php/mv/msg/1089469/1774605/#msg_1774605
Tauno Voipio2017-10-17T17:14:35-00:00Re: Trouble building projects the second time
https://www.eclipse.org/forums/index.php/mv/msg/1089469/1774611/#msg_1774611
I thought the same. But the problem is that I cannot locate where the file may be running. Task manager does not show an exe by the name of my project/program.
I want to find solutions to two problems
1) How do I locate where are the exe files open? Task manager is not the one helping me.
2) How can I set up my system in a manner that I don't have to manually close the exe everytime?
