INFO: T#01ms: FORTE is up and running INFO: T#04ms: Using default bootfile location: forte.fboot WARNING: T#08ms: Boot file forte.fboot could not be opened. Skipping... INFO: T#012ms: CWin32SocketInterface: Opening TCP-Server connection at: localhost:61499
SDT().setCurrentTime();
-fsanitize=address
-fsanitize=undefined]
In file C:/.../forte_thread.cpp:18:0: c:\sysgcc\raspberry\arm-linux-gnueabihf\include\sys\wait.h:102:22: error: '__WAIT_STATUS' was not declared in this scope extern __pid_t wait (__WAIT_STATUS __stat_loc);
HTTP/1.1 200 OK Content-Type: text/plain 1858.656 e="http[192.168.10.193:7000/rest/devices/battery/M03]" forced="false"></Data></Port><Port name="QI"><Data value="TRUE" forced="false"></Data></Port><Port name="QO"><Data value="FALSE" forced="false"></Data></Port><Port name="STATUS"><Data value="" forced="false"></Data></Port><Port name="RD_1"><Data value="0" forced="false"></Data></Port><Port name="INIT"><Data value="0" time="0"></Data></Port><Port name="REQ"><Data value=
if ((cg_unIPLayerRecvBufferSize - m_unBufFillSize) <= 0) { // If buffer is full, clear and return memset(&m_acRecvBuffer[0], 0, sizeof(m_acRecvBuffer)); m_unBufFillSize = 0; m_eInterruptResp = e_ProcessDataRecvFaild; DEVLOG_INFO("HTTP recv buffer full\n"); return; }
INFO: T#014761348ms: Unexpected HTTP GET response code INFO: T#014761348ms: CBSDSocketInterface: Opening TCP-Client connection at: 192.168.10.101:7979
INFO: T#017081859ms: Handling received HTTP response INFO: T#017081859ms: Unexpected HTTP PUT response code INFO: T#017081859ms: CBSDSocketInterface: Opening TCP-Client connection at: 192.168.10.101:7979 INFO: T#017081860ms: Sending request on TCP INFO: T#017081860ms: Attempting to receive data from TCP
strncpy(request, requestCache, strlen(requestCache) + 1); openConnection(); if (0 >= CIPComSocketHandler::sendDataOnTCP(m_nSocketID, request, pa_unSize)) {
struct timeval tv; // Timeout tv.tv_sec = 10; tv.tv_usec = 10000; fd_set fdset; FD_ZERO(&fdset); FD_SET(m_nSocketID, &fdset); if (select(1, &fdset, NULL, NULL, &tv) > 0) { // call receiveDataFromTCP() } else { nRetVal = -1; DEVLOG_INFO("No data received from TCP\n"); }
