Eclipse Community Forumspassing arguments from Java to EOL
https://www.eclipse.org/forums/index.php/mv/msg/1088845/1772681/#msg_1772681
I am trying to pass arguments from .java file to .eol file and wants .eol to use those parameter and do further operation.
If I use below code to pass parameter
Variable parameters = new Variable("messageIds", hashMapSet, EolCollectionType.Set);
module.getContext().getFrameStack().put(parameters);
I am not sure how .eol file is going to receive it.
I am calling .eol file programatically from java and not running through run configuration.
Is there any other way where arguments can be passed from java to .eol file.
Once you do this, you should be able to use that "messageIds" variable normally from inside your EOL file.]]>Antonio Garcia-Dominguez2017-09-14T10:07:02-00:00
