Eclipse Community ForumsJubula extension component !
https://www.eclipse.org/forums/index.php/mv/msg/1086050/1761156/#msg_1761156
I'm Working With Eclipse Testing Neon and I'm New To, I'm Testing A JavaFX Application , When I've Tried To Map Some Componemt Inside A Tabpane , Jubula Doesn't Recognize Them .
I've Read About Extension But It Seems That I Do Not Get Quite Well The Steps.
Can Anyone Help Me With A Demonstration.
Thanks ]]>Khemiri Mahran2017-05-08T10:40:05-00:00Re: Jubula extension component !
https://www.eclipse.org/forums/index.php/mv/msg/1086050/1761460/#msg_1761460
There might be different things going on. Either there is a really not supported component, or the container(the tabPane) is not supported as a Container. If you would have used the Jubula Standalone there would also be the possibility that you could try to support the component via SimpleExtension. For more information regarding the complex extension writing see [1]
