Eclipse Community Forumsneon.3 and Papyrus
https://www.eclipse.org/forums/index.php/mv/msg/1085941/1760835/#msg_1760835
Apologies, originally, I managed to get this posted on newcomers--wrong place let's try again.
Is Papyrus out of synch with eclipse versions?
I am just starting out with Papyrus. I have it installed along with Accelleo on my neon.3 IDE--latest and greatest everything. I can neither created a class diagram nor can I open a class diagram that was created using another Papyrus installation.
On create: The dialogs appear. I complete them, but the finish button does nothing. I click, the dialog remains, no diagram is created.
On open existing: A tab appears in the editor space showing an X in the tab and blank in the editor.
While we're at it, I use a theme with a dark background. Does Papyrus expect me to use a light background?
Papyrus/Acceleo has good potential in my current work. I hope to find a way to work with these problems.
Thanks]]>Geoffry Roberts2017-05-03T13:40:25-00:00Re: neon.3 and Papyrus
https://www.eclipse.org/forums/index.php/mv/msg/1085941/1760837/#msg_1760837
it's glad and sad at the same time that I'm not the only one experiencing this behaviour.
I have two papyrus(es) running here: One that was already downloaded as "standalone" (in quotes, since I'm aware of the fact, that it is only a preconfigured eclipse) Papyrus. If I search for updates on this one, it seems to not update itself to neon.3. The other one is a Papyrus plugin installed in a normal eclipse IDE. If I search for updates in this one, it updates to neon.3 and after the update, it shows the same symptoms as you describe (Wizards don't react on finish button, existing models show only a blank tab...).
I use eclipse with the default bright background, so this doesn't seem to be the culprit.
Cheers
Benedikt]]>Benedikt Bauer2017-05-03T13:56:19-00:00Re: neon.3 and Papyrus
https://www.eclipse.org/forums/index.php/mv/msg/1085941/1761019/#msg_1761019
That is a very strange behavior indeed. I just downloaded a fresh Neon3 and installed the released version of papyrus for Neon [1] and everything (with and without acceleo) seems to work fine. And I agree with Benedikt, the background shouldn't bring about such behavior.
Could one of you (or both) give us a more detailed view of the installed plugins please, so that we could reproduce your problem ?
Quentin
[1] http://download.eclipse.org/modeling/mdt/papyrus/updates/releases/neon]]>Quentin Le Menez2017-05-05T10:12:37-00:00Re: neon.3 and Papyrus
https://www.eclipse.org/forums/index.php/mv/msg/1085941/1761053/#msg_1761053
My neon is not a fresh install. I've updated it twice. It was after the first update that I installed Papyrus and Acceleo. Both worked well except for issues with the dark background. I then did the second update and that's when things broke.
I will say that my neon has a lot of stuff installed.]]>Geoffry Roberts2017-05-05T17:42:22-00:00Re: neon.3 and Papyrus
https://www.eclipse.org/forums/index.php/mv/msg/1085941/1761472/#msg_1761472
I did notice however that papyrus does not seem to respond to preference settings wrt colors. I use a dark background and the connecting lines default to black and I cannot change them globally using the preferences. I have to change each line individually as I create it. ]]>Geoffry Roberts2017-05-11T12:16:30-00:00
