Eclipse Community ForumscustodianAddress and custodianTelecom Exception
https://www.eclipse.org/forums/index.php/mv/msg/1085093/1757902/#msg_1757902
// custodianAddress
AD custodianAddress = DatatypesFactory.eINSTANCE.createAD();
custodianOrganization.getAddrs().add(custodianAddress);
//Custodian Telecom
TEL custodianTel=DatatypesFactory.eINSTANCE.createTEL("tel:+1-(xxx)xxx-xxxx");
custodianOrganization.getTelecoms().add(custodianTel);
Exception
Exception in thread "main" java.lang.UnsupportedOperationException
at org.eclipse.emf.common.util.BasicEList$UnmodifiableEList.add(BasicEList.java:909)
at src_test.CreateDischargeSummary.main(CreateDischargeSummary.java:218)
]]>Mostafa Elhefnawy2017-03-21T15:01:47-00:00Re: custodianAddress and custodianTelecom Exception
https://www.eclipse.org/forums/index.php/mv/msg/1085093/1757928/#msg_1757928
Show the full context/source/what you are trying to do and maybe I can see a workaround for it.]]>Dan Brown2017-03-21T22:07:52-00:00Re: custodianAddress and custodianTelecom Exception
https://www.eclipse.org/forums/index.php/mv/msg/1085093/1757930/#msg_1757930
Mostafa Elhefnawy2017-03-21T22:22:11-00:00
