Eclipse Community ForumsSort node order from left to right LayeredLayoutProvider
https://www.eclipse.org/forums/index.php/mv/msg/1084815/1755613/#msg_1755613
is it possible to sort the nodes for the layouting? For example i have starting nodes which i need to show on the most left of the diagram and items which should be shown in the central part and on the most right part i have to show the finish elements.
For example:
StartNode -> Processesing Nodes -> Termination/Final Node(s).
like in a BPMN diagram. Thanks in advance.
Best Regards
M.Emin
]]>Mehmet Karaman2017-03-06T10:43:38-00:00Re: Sort node order from left to right LayeredLayoutProvider
https://www.eclipse.org/forums/index.php/mv/msg/1084815/1755616/#msg_1755616
Layer Constraint option on the start nodes and final nodes.]]>Miro Spönemann2017-03-06T10:52:14-00:00
