... :jpl.imce.oml.specification:generateXtextLanguage 0 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/emf/2002/Ecore' from 'platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel' 32 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.w3.org/XML/1998/namespace' from 'platform:/resource/org.eclipse.emf.ecore/model/XMLNamespace.genmodel' 58 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/emf/2003/XMLType' from 'platform:/resource/org.eclipse.emf.ecore/model/XMLType.genmodel' 149 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'org.eclipse.xtext.xbase.XbasePackage' 235 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/Xtext/Xbase/XAnnotations' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel' 271 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xtype' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel' 289 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xbase' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel' 290 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/common/JavaVMTypes' from 'platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel' 2605 [main] INFO text.xtext.generator.XtextGenerator - Initializing Xtext generator 2606 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'org.eclipse.xtext.common.types.TypesPackage' 2743 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project jpl.imce.oml.specification at 'file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/' 2744 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project jpl.imce.oml.specification.tests at 'file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification.tests/' 2744 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project jpl.imce.oml.specification.ide at 'file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification.ide/' 2744 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project jpl.imce.oml.specification.ui at 'file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification.ui/' 2744 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project jpl.imce.oml.specification.ui.tests at 'file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification.ui.tests/' 2744 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project jpl.imce.oml.specification.idea at 'file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification.idea/' 2745 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project jpl.imce.oml.specification.web at 'file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification.web/' 2767 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Using resourceSet registry. The registered Packages will not be registered in the global EPackage.Registry.INSTANCE! 5088 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'xcore.lang' from 'platform:/resource/org.eclipse.emf.ecore.xcore.lib/model/XcoreLang.xcore' 6869 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://imce.jpl.nasa.gov/oml/common' from 'platform:/resource/jpl.imce.oml.specification.ecore/model/OMLCommon.xcore' 6878 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://imce.jpl.nasa.gov/oml/terminologies' from 'platform:/resource/jpl.imce.oml.specification.ecore/model/OMLTerminologies.xcore' 6878 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://imce.jpl.nasa.gov/oml/graphs' from 'platform:/resource/jpl.imce.oml.specification.ecore/model/OMLGraphs.xcore' 6878 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://imce.jpl.nasa.gov/oml/bundles' from 'platform:/resource/jpl.imce.oml.specification.ecore/model/OMLBundles.xcore' 6879 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://imce.jpl.nasa.gov/oml/descriptions' from 'platform:/resource/jpl.imce.oml.specification.ecore/model/OMLDescriptions.xcore' 15757 [main] INFO erator.parser.antlr.AntlrToolFacade - downloading file from 'http://download.itemis.com/antlr-generator-3.2.0-patch.jar' ... 17219 [main] INFO erator.parser.antlr.AntlrToolFacade - finished downloading. 17238 [main] INFO text.xtext.generator.XtextGenerator - Generating jpl.imce.oml.specification.OntologicalModelingLanguage 51980 [main] INFO text.xtext.generator.XtextGenerator - Generating common infrastructure 52007 [main] INFO .emf.mwe2.runtime.workflow.Workflow - Done. :jpl.imce.oml.specification:generateXtextWarning: NLS unused message: auth_alreadySpecified in: org.eclipse.core.internal.runtime.messages Warning: NLS missing message: line_separator_platform_mac_os_9 in: org.eclipse.core.internal.runtime.messages ERROR:The method getAnnotationPropertyAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 57 column : 41) ERROR:The method getAnnotationPropertyAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 58 column : 41) ERROR:The method getAnnotationAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 64 column : 33) ERROR:The method getAnnotationAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 65 column : 33) ERROR:The method getTerminologyGraphAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 72 column : 39) ERROR:The method getTerminologyGraphAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 73 column : 39) ERROR:The method getTerminologyGraphAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 75 column : 52) ERROR:The method getTerminologyGraphAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 76 column : 52) ERROR:The method getTerminologyGraphAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 99 column : 42) ERROR:The method getTerminologyGraphAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 100 column : 42) ERROR:The method getTerminologyGraphAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 128 column : 50) ERROR:The method getTerminologyGraphAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 129 column : 50) ERROR:The method getAspectAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 140 column : 29) ERROR:The method getAspectAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 141 column : 29) ERROR:The method getTerminologyExtensionAxiomAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 146 column : 25) ERROR:The method getTerminologyExtensionAxiomAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 147 column : 25) FAILED FAILURE: Build failed with an exception. * What went wrong: Execution failed for task ':jpl.imce.oml.specification:generateXtext'. > Xtext validation failed, see build log for details. * Try: Run with --info or --debug option to get more log output. * Exception is: org.gradle.api.tasks.TaskExecutionException: Execution failed for task ':jpl.imce.oml.specification:generateXtext'. at org.gradle.api.internal.tasks.execution.ExecuteActionsTaskExecuter.executeActions(ExecuteActionsTaskExecuter.java:84) at org.gradle.api.internal.tasks.execution.ExecuteActionsTaskExecuter.execute(ExecuteActionsTaskExecuter.java:55) at org.gradle.api.internal.tasks.execution.SkipUpToDateTaskExecuter.execute(SkipUpToDateTaskExecuter.java:62) at org.gradle.api.internal.tasks.execution.ValidatingTaskExecuter.execute(ValidatingTaskExecuter.java:58) at org.gradle.api.internal.tasks.execution.SkipEmptySourceFilesTaskExecuter.execute(SkipEmptySourceFilesTaskExecuter.java:88) at org.gradle.api.internal.tasks.execution.ResolveTaskArtifactStateTaskExecuter.execute(ResolveTaskArtifactStateTaskExecuter.java:46) at org.gradle.api.internal.tasks.execution.SkipTaskWithNoActionsExecuter.execute(SkipTaskWithNoActionsExecuter.java:51) at org.gradle.api.internal.tasks.execution.SkipOnlyIfTaskExecuter.execute(SkipOnlyIfTaskExecuter.java:54) at org.gradle.api.internal.tasks.execution.ExecuteAtMostOnceTaskExecuter.execute(ExecuteAtMostOnceTaskExecuter.java:43) at org.gradle.api.internal.tasks.execution.CatchExceptionTaskExecuter.execute(CatchExceptionTaskExecuter.java:34) at org.gradle.execution.taskgraph.DefaultTaskGraphExecuter$EventFiringTaskWorker$1.execute(DefaultTaskGraphExecuter.java:236) at org.gradle.execution.taskgraph.DefaultTaskGraphExecuter$EventFiringTaskWorker$1.execute(DefaultTaskGraphExecuter.java:228) at org.gradle.internal.Transformers$4.transform(Transformers.java:169) at org.gradle.internal.progress.DefaultBuildOperationExecutor.run(DefaultBuildOperationExecutor.java:106) at org.gradle.internal.progress.DefaultBuildOperationExecutor.run(DefaultBuildOperationExecutor.java:61) at org.gradle.execution.taskgraph.DefaultTaskGraphExecuter$EventFiringTaskWorker.execute(DefaultTaskGraphExecuter.java:228) at org.gradle.execution.taskgraph.DefaultTaskGraphExecuter$EventFiringTaskWorker.execute(DefaultTaskGraphExecuter.java:215) at org.gradle.execution.taskgraph.AbstractTaskPlanExecutor$TaskExecutorWorker.processTask(AbstractTaskPlanExecutor.java:77) at org.gradle.execution.taskgraph.AbstractTaskPlanExecutor$TaskExecutorWorker.run(AbstractTaskPlanExecutor.java:58) at org.gradle.execution.taskgraph.DefaultTaskPlanExecutor.process(DefaultTaskPlanExecutor.java:32) at org.gradle.execution.taskgraph.DefaultTaskGraphExecuter.execute(DefaultTaskGraphExecuter.java:113) at org.gradle.execution.SelectedTaskExecutionAction.execute(SelectedTaskExecutionAction.java:37) at org.gradle.execution.DefaultBuildExecuter.execute(DefaultBuildExecuter.java:37) at org.gradle.execution.DefaultBuildExecuter.access$000(DefaultBuildExecuter.java:23) at org.gradle.execution.DefaultBuildExecuter$1.proceed(DefaultBuildExecuter.java:43) at org.gradle.execution.DryRunBuildExecutionAction.execute(DryRunBuildExecutionAction.java:32) at org.gradle.execution.DefaultBuildExecuter.execute(DefaultBuildExecuter.java:37) at org.gradle.execution.DefaultBuildExecuter.execute(DefaultBuildExecuter.java:30) at org.gradle.initialization.DefaultGradleLauncher$RunTasksAction.execute(DefaultGradleLauncher.java:256) at org.gradle.initialization.DefaultGradleLauncher$RunTasksAction.execute(DefaultGradleLauncher.java:253) at org.gradle.internal.Transformers$4.transform(Transformers.java:169) at org.gradle.internal.progress.DefaultBuildOperationExecutor.run(DefaultBuildOperationExecutor.java:106) at org.gradle.internal.progress.DefaultBuildOperationExecutor.run(DefaultBuildOperationExecutor.java:56) at org.gradle.initialization.DefaultGradleLauncher.doBuildStages(DefaultGradleLauncher.java:175) at org.gradle.initialization.DefaultGradleLauncher.doBuild(DefaultGradleLauncher.java:119) at org.gradle.initialization.DefaultGradleLauncher.run(DefaultGradleLauncher.java:102) at org.gradle.launcher.exec.GradleBuildController.run(GradleBuildController.java:71) at org.gradle.tooling.internal.provider.ExecuteBuildActionRunner.run(ExecuteBuildActionRunner.java:28) at org.gradle.launcher.exec.ChainingBuildActionRunner.run(ChainingBuildActionRunner.java:35) at org.gradle.launcher.exec.InProcessBuildActionExecuter.execute(InProcessBuildActionExecuter.java:41) at org.gradle.launcher.exec.InProcessBuildActionExecuter.execute(InProcessBuildActionExecuter.java:26) at org.gradle.tooling.internal.provider.ContinuousBuildActionExecuter.execute(ContinuousBuildActionExecuter.java:75) at org.gradle.tooling.internal.provider.ContinuousBuildActionExecuter.execute(ContinuousBuildActionExecuter.java:49) at org.gradle.tooling.internal.provider.ServicesSetupBuildActionExecuter.execute(ServicesSetupBuildActionExecuter.java:49) at org.gradle.tooling.internal.provider.ServicesSetupBuildActionExecuter.execute(ServicesSetupBuildActionExecuter.java:31) at org.gradle.launcher.daemon.server.exec.ExecuteBuild.doBuild(ExecuteBuild.java:67) at org.gradle.launcher.daemon.server.exec.BuildCommandOnly.execute(BuildCommandOnly.java:36) at org.gradle.launcher.daemon.server.api.DaemonCommandExecution.proceed(DaemonCommandExecution.java:120) at org.gradle.launcher.daemon.server.exec.WatchForDisconnection.execute(WatchForDisconnection.java:47) at org.gradle.launcher.daemon.server.api.DaemonCommandExecution.proceed(DaemonCommandExecution.java:120) at org.gradle.launcher.daemon.server.exec.ResetDeprecationLogger.execute(ResetDeprecationLogger.java:26) at org.gradle.launcher.daemon.server.api.DaemonCommandExecution.proceed(DaemonCommandExecution.java:120) at org.gradle.launcher.daemon.server.exec.RequestStopIfSingleUsedDaemon.execute(RequestStopIfSingleUsedDaemon.java:34) at org.gradle.launcher.daemon.server.api.DaemonCommandExecution.proceed(DaemonCommandExecution.java:120) at org.gradle.launcher.daemon.server.exec.ForwardClientInput$2.call(ForwardClientInput.java:74) at org.gradle.launcher.daemon.server.exec.ForwardClientInput$2.call(ForwardClientInput.java:72) at org.gradle.util.Swapper.swap(Swapper.java:38) at org.gradle.launcher.daemon.server.exec.ForwardClientInput.execute(ForwardClientInput.java:72) at org.gradle.launcher.daemon.server.api.DaemonCommandExecution.proceed(DaemonCommandExecution.java:120) at org.gradle.launcher.daemon.server.exec.LogAndCheckHealth.execute(LogAndCheckHealth.java:55) at org.gradle.launcher.daemon.server.api.DaemonCommandExecution.proceed(DaemonCommandExecution.java:120) at org.gradle.launcher.daemon.server.exec.LogToClient.doBuild(LogToClient.java:60) at org.gradle.launcher.daemon.server.exec.BuildCommandOnly.execute(BuildCommandOnly.java:36) at org.gradle.launcher.daemon.server.api.DaemonCommandExecution.proceed(DaemonCommandExecution.java:120) at org.gradle.launcher.daemon.server.exec.EstablishBuildEnvironment.doBuild(EstablishBuildEnvironment.java:72) at org.gradle.launcher.daemon.server.exec.BuildCommandOnly.execute(BuildCommandOnly.java:36) at org.gradle.launcher.daemon.server.api.DaemonCommandExecution.proceed(DaemonCommandExecution.java:120) at org.gradle.launcher.daemon.server.exec.StartBuildOrRespondWithBusy$1.run(StartBuildOrRespondWithBusy.java:50) at org.gradle.launcher.daemon.server.DaemonStateCoordinator$1.run(DaemonStateCoordinator.java:297) at org.gradle.internal.concurrent.ExecutorPolicy$CatchAndRecordFailures.onExecute(ExecutorPolicy.java:63) at org.gradle.internal.concurrent.StoppableExecutorImpl$1.run(StoppableExecutorImpl.java:46) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:745) Caused by: org.gradle.api.GradleException: Xtext validation failed, see build log for details. at org.xtext.gradle.builder.XtextGradleBuilder.build(XtextGradleBuilder.java:210) at org.xtext.gradle.tasks.XtextGenerate.generate(XtextGenerate.java:149) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:483) at org.gradle.internal.reflect.JavaMethod.invoke(JavaMethod.java:73) at org.gradle.api.internal.project.taskfactory.DefaultTaskClassInfoStore$IncrementalTaskAction.doExecute(DefaultTaskClassInfoStore.java:163) at org.gradle.api.internal.project.taskfactory.DefaultTaskClassInfoStore$StandardTaskAction.execute(DefaultTaskClassInfoStore.java:134) at org.gradle.api.internal.project.taskfactory.DefaultTaskClassInfoStore$StandardTaskAction.execute(DefaultTaskClassInfoStore.java:123) at org.gradle.api.internal.tasks.execution.ExecuteActionsTaskExecuter.executeAction(ExecuteActionsTaskExecuter.java:95) at org.gradle.api.internal.tasks.execution.ExecuteActionsTaskExecuter.executeActions(ExecuteActionsTaskExecuter.java:76) ... 73 more
