Eclipse Community ForumsError installing Eclipse - Requiring JVM
https://www.eclipse.org/forums/index.php/mv/msg/1083694/1751754/#msg_1751754
Incompatible JVM
Version 1.7.0_75 of the JVM is not suitable for this product. Version: 1.8 or greater is required.
OK
Except my java is already up to date. Tried to follow some topics with the same problem, but all of them say to edit eclipse .ini files and so, but I am using the installer .exe, so nothing else to do.
I took a screenshot showing the java version, error and the file i am trying to execute
Thank you!]]>EVERSON JUNIOR2017-01-13T13:46:13-00:00Re: Error installing Eclipse - Requiring JVM
https://www.eclipse.org/forums/index.php/mv/msg/1083694/1751756/#msg_1751756
Nitin Dahyabhai2017-01-13T14:14:01-00:00Re: Error installing Eclipse - Requiring JVM
https://www.eclipse.org/forums/index.php/mv/msg/1083694/1751875/#msg_1751875
Thank you!]]>EVERSON JUNIOR2017-01-16T12:06:58-00:00Re: Error installing Eclipse - Requiring JVM
https://www.eclipse.org/forums/index.php/mv/msg/1083694/1765096/#msg_1765096
Ambre SOUBIRAN2017-06-06T14:24:33-00:00Re: Error installing Eclipse - Requiring JVM
https://www.eclipse.org/forums/index.php/mv/msg/1083694/1765107/#msg_1765107
http://www.oracle.com/technetwork/java/javase/downloads/index-jsp-138363.html]]>Ed Merks2017-06-06T17:20:30-00:00Re: Hi
https://www.eclipse.org/forums/index.php/mv/msg/1083694/1775975/#msg_1775975
Bob Ericksen2017-11-08T17:48:58-00:00Re: Hi
https://www.eclipse.org/forums/index.php/mv/msg/1083694/1775979/#msg_1775979
Nitin Dahyabhai2017-11-08T19:33:12-00:00Re: Hi
https://www.eclipse.org/forums/index.php/mv/msg/1083694/1775985/#msg_1775985
Thank you very much!!!]]>Bob Ericksen2017-11-08T21:27:35-00:00Re: Hi
https://www.eclipse.org/forums/index.php/mv/msg/1083694/1775986/#msg_1775986
Thank you very much!!!]]>Bob Ericksen2017-11-08T21:28:02-00:00Re: Error installing Eclipse - Requiring JVM
https://www.eclipse.org/forums/index.php/mv/msg/1083694/1783849/#msg_1783849
Eclipse IDE for Java Developers
Version: Oxygen.2 Release (4.7.2)
Build id: 20171218-0600
Resolved by installing Java 9 SE Development kit 9.0.4
]]>Geoff Armstrong2018-03-19T11:58:27-00:00
