private void updateNavigationHistory(IWorkbenchPartReference partRef, boolean partClosed) {
if (partRef != null && partRef.getPart(false) instanceof IEditorPart) {
IEditorPart editor = (IEditorPart) partRef.getPart(false);
IEditorInput input = editor.getEditorInput();
String id = editor.getSite().getId();
Iterator e = editors.iterator();
NavigationHistoryEditorInfo info = null;
NavigationHistoryEditorInfo currentInfo = null;
NavigationHistoryEntry current = getEntry(activeEntry);
if (current != null) {
currentInfo = current.editorInfo;
while (e.hasNext()) {
info = (NavigationHistoryEditorInfo) e.next();
if (id.equals(info.editorID)
>>>>>>>>>>>> && input.equals(info.editorInput)) { <<<<<<<<<<<<<<<<<<<<<<<< NPE HERE!
if (partClosed && info != currentInfo) {
info.handlePartClosed();
break;
info = null;
if (info == null) {
return;
!ENTRY org.eclipse.ui.workbench 4 2 2017-01-05 14:30:16.807
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 0
at org.eclipse.ui.internal.NavigationHistory$1.updateNavigationHistory(NavigationHistory.java:123)
at org.eclipse.ui.internal.NavigationHistory$1.partClosed(NavigationHistory.java:100)
at org.eclipse.ui.internal.WorkbenchPage$25.run(WorkbenchPage.java:5135)
at org.eclipse.ui.internal.WorkbenchPage.firePartClosed(WorkbenchPage.java:5132)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart$1.handleEvent(CompatibilityPart.java:102)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:5406)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setWidget(UIElementImpl.java:261)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.unbindWidget(SWTPartRenderer.java:151)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.disposeWidget(SWTPartRenderer.java:174)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.disposeWidget(ContributedPartRenderer.java:272)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:918)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$1(PartRenderingEngine.java:846)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$3.run(PartRenderingEngine.java:841)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.removeGui(PartRenderingEngine.java:825)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.subscribeTopicToBeRendered(PartRenderingEngine.java:173)
at sun.reflect.DelegatingMethodAccessorImpl.__invoke(DelegatingMethodAccessorImpl.java:43)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler.handleEvent(EventObjectSupplier.java:80)
at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setToBeRendered(UIElementImpl.java:303)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.hidePart(PartServiceImpl.java:1350)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.hidePart(PartServiceImpl.java:1284)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.closePart(StackRenderer.java:1289)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.access$2(StackRenderer.java:1271)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer$7.close(StackRenderer.java:1156)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1930)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:338)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5219)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1340)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4553)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4143)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:687)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:604)
at org.corpus_tools.atomic.Atomic.start(Atomic.java:64)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
