Eclipse Community Forumsproblem when try to add mn(in Raspberry Pi) in my IN(pc)
https://www.eclipse.org/forums/index.php/mv/msg/1078512/1735356/#msg_1735356
I start working on OM2M for about 2months and my purpose is to use Raspberry Pi 3 as a MN and my computer as an IN.
After a successful build in both of the two devices.
I am trying to add MN in my IN. but it showed up a error (Name is not permitted). Please see the screenshots below.
At the same time, i tried add MN(using the same pc of IN) in my IN, and it works.
Could you guys help me to walk out of this problem, thank you guys very much.]]>Can LIU2016-06-17T15:28:10-00:00Re: problem when try to add mn(in Raspberry Pi) in my IN(pc)
https://www.eclipse.org/forums/index.php/mv/msg/1078512/1735359/#msg_1735359
configuration of IN:
log4j.configuration=file\:./log4j.configuration
org.eclipse.equinox.http.jetty.http.port=8080
org.eclipse.om2m.dbReset=true
org.eclipse.om2m.cseBaseContext=/
org.eclipse.om2m.globalContext=
org.eclipse.om2m.cseBaseProtocol.default=http
org.eclipse.om2m.cseBaseName=in-name
org.eclipse.om2m.cseBaseAddress= IP de PC
org.eclipse.om2m.dbUrl=jdbc\:h2\:./database/indb
osgi.framework.extensions=
org.eclipse.om2m.webInterfaceContext=/webpage
osgi.bundles.defaultStartLevel=4
org.eclipse.om2m.dbUser=om2m
osgi.framework=file\:plugins/org.eclipse.osgi_3.10.2.v20150203-1939.jar
org.eclipse.om2m.guestRequestingEntity=guest\:guest
org.eclipse.om2m.cseBaseId=in-cse
org.eclipse.om2m.dbDriver=org.h2.Driver
org.eclipse.om2m.adminRequestingEntity=admin\:admin
org.eclipse.om2m.cseType=IN-CSE
org.apache.commons.logging.Log=org.apache.commons.logging.impl.Log4JLogger
eclipse.p2.data.area=@config.dir/../p2
org.eclipse.om2m.resource.idseparator=-
org.eclipse.om2m.coap.port=5683
org.eclipse.om2m.dbPassword=om2m
org.eclipse.om2m.m2mSpId=om2m.org
configuration of MN:
org.eclipse.om2m.remoteCseId=in-cse
org.eclipse.equinox.http.jetty.http.port=8282
org.eclipse.om2m.remoteCsePort=8080
org.eclipse.om2m.cseBaseName=mn-name
org.eclipse.om2m.cseBaseAddress=Ip de Raspberry Pi
eclipse.p2.profile=DefaultProfile
org.eclipse.om2m.dbUrl=jdbc\:h2\:./database/mndb
org.eclipse.om2m.maxNrOfInstances=1000
org.eclipse.om2m.remoteCseName=in-name
org.eclipse.om2m.cseBaseId=mn-cse
org.eclipse.om2m.remoteCseContext=/
org.eclipse.om2m.remoteCseAddress=IP de PC
org.eclipse.om2m.cseType=MN
org.eclipse.om2m.cseAuthentication=true
org.eclipse.om2m.coap.port=5684
]]>Can LIU2016-06-17T15:39:04-00:00Re: problem when try to add mn(in Raspberry Pi) in my IN(pc)
https://www.eclipse.org/forums/index.php/mv/msg/1078512/1735892/#msg_1735892
First of all, I would like to ensure that you use the latest version of our code. Could you please try to pull the master branch of OM2M?
The oneM2M standard published an intermediary release recently and we implemented it. This could solve this error.
Guillaume]]>Guillaume Garzone2016-06-23T12:57:49-00:00Re: problem when try to add mn(in Raspberry Pi) in my IN(pc)
https://www.eclipse.org/forums/index.php/mv/msg/1078512/1735912/#msg_1735912
Thank you very much, i saw that there is a bug which is already fixed about this error, after build the latest release of OM2M, i solved this error.
Best Regards
Can]]>Can LIU2016-06-23T14:23:01-00:00
