Eclipse Community ForumsCallin Marker Create maxing out CPU - eclipse is frozen
https://www.eclipse.org/forums/index.php/mv/msg/1078428/1735057/#msg_1735057
using eclipse MARS.2 (release 4.5.2 - build 20160218-0600) on windows 7.
Every now and then - certainly too often - some process in eclipse starts which I can see in the bottom right status bar: "Callin Marker Creater (x%)". I saw it with 15% and then with 19%. The java process on windows task manager is maxed out, eclipse is unresponsive.
Please does anyone know anything about this problem?
I googled and found a very old thread (on bugs.eclipse.org no 317352) claiming that his process is firing too many jobs. But the status of this bug/fix is VERIFIED_FIXED. But I cannot confirm that - far from fixed!
It happens now on a daily basis and I am unable to work properly as I have to kill eclipse and restart.
I hope and appreciate any help on this. Any way to uninstall this plugin or get a fix for it?
