Eclipse Community Forums[ZEST 1] Disable animation
https://www.eclipse.org/forums/index.php/mv/msg/1076872/1730354/#msg_1730354
was the old ZEST (1.x) API enhanced for turning off the animation?
Thanks for your support!
Wladimir]]>Wladimir Schamai2016-04-25T09:07:45-00:00Re: [ZEST 1] Disable animation
https://www.eclipse.org/forums/index.php/mv/msg/1076872/1730356/#msg_1730356
Alexander Nyssen2016-04-25T09:18:25-00:00Re: [ZEST 1] Disable animation
https://www.eclipse.org/forums/index.php/mv/msg/1076872/1730358/#msg_1730358
thanks for your reply.
ZEST 1.x (the one form http://download.eclipse.org/tools/gef/updates/releases/) offers animation but no way to turn it off or reduce the animation time.
We are still using it and, and now we need to turn off animation because it unnecessarily consumes 500ms of time.
Does it mean that the ZEST 1.x is not maintained anymore? ]]>Wladimir Schamai2016-04-25T09:29:23-00:00Re: [ZEST 1] Disable animation
https://www.eclipse.org/forums/index.php/mv/msg/1076872/1730380/#msg_1730380
The status of Zest 1.x is "pure maintenance". That is, we will fix problems as long as we can do without breaking API. We do not actively develop it further. Our focus is on its successor, GEF4 Zest.]]>Alexander Nyssen2016-04-25T11:13:11-00:00Re: [ZEST 1] Disable animation
https://www.eclipse.org/forums/index.php/mv/msg/1076872/1730407/#msg_1730407
Do you think it is feasible remove the final modifier from
public static final int ANIMATION_TIME = 500;
in org.eclipse.zest.core.widgets.Graph?
That would already solve our issue because then we could reduce the animation time to a minimum. This would not break the API, right?
]]>Wladimir Schamai2016-04-25T14:18:15-00:00Re: [ZEST 1] Disable animation
https://www.eclipse.org/forums/index.php/mv/msg/1076872/1730413/#msg_1730413
Alexander Nyssen2016-04-25T14:46:43-00:00Re: [ZEST 1] Disable animation
https://www.eclipse.org/forums/index.php/mv/msg/1076872/1730428/#msg_1730428
GraphViewer viewer = new GraphViewer(parent, SWT.None);
viewer.setNodeStyle(ZestStyles.NODES_NO_LAYOUT_ANIMATION);
Or do I miss something in this conversation?]]>Erdal Karaca2016-04-25T18:45:16-00:00Re: [ZEST 1] Disable animation
https://www.eclipse.org/forums/index.php/mv/msg/1076872/1730429/#msg_1730429
https://bugs.eclipse.org/bugs/show_bug.cgi?id=273585]]>Erdal Karaca2016-04-25T18:48:05-00:00Re: [ZEST 1] Disable animation
https://www.eclipse.org/forums/index.php/mv/msg/1076872/1730472/#msg_1730472
It was no obvious to me that can be defined for viewer.
@Alexander, thanks, my issue is solved.
]]>Wladimir Schamai2016-04-26T07:08:19-00:00Re: [ZEST 1] Disable animation
https://www.eclipse.org/forums/index.php/mv/msg/1076872/1730478/#msg_1730478
Alexander Nyssen2016-04-26T08:38:27-00:00
