Eclipse Community ForumsJEP 223: New Version-String Scheme - Window Builder not working
https://www.eclipse.org/forums/index.php/mv/msg/1075300/1725405/#msg_1725405
Window builder has problem with recognition JDK-9 ( the same problem had Mars 1 but Mars 2 working OK ), design page warning:
Eclipse is running under 0, but
this Java project has a 1.7 Java compliance level, so will not be able to load classes
from this project. Use a lower level of Java for the project, or run Eclipse using a newer Java
version.
Best regards
Krzysztof]]>2016-03-03T10:20:19-00:00
