Eclipse Community ForumsDirigible CodeWeek Workshop - Feedback
https://www.eclipse.org/forums/index.php/mv/msg/1071310/1711657/#msg_1711657
http://events.codeweek.eu/view/6000/eclipse-dirigible-cloud-dev-workshop/]]>2015-10-19T07:02:44-00:00Re: Dirigible CodeWeek Workshop - Feedback
https://www.eclipse.org/forums/index.php/mv/msg/1071310/1711667/#msg_1711667
2. Git Repository vs. Operational Repository
3. How can I add Erlang or another non-JVM language
4. How to use Riak or another noSQL database
5. How to re-brand Dirigible
6. HTML5 templates too basic - validation, specialised widgets
7. New templates - UI5
8. Activate/Publish still not clear enough when to use what
9. Migration procedure for projects - versioning, db schema
10. Built-in user management (+ default login,logout,error pages) - jump-start for students
11. How to export and import projects and data
12. Specific binary export for mobile, erlang, WAR
13. Extended log view for errors in monitoring - only errors with better visualisation and context
14. Web IDE for Java - what is the plan?
15 dirigible.io site - to provide information per groups - education, business, RCP developers, Open Source developers, etc.]]>2015-10-19T07:39:14-00:00Re: Dirigible CodeWeek Workshop - Feedback
https://www.eclipse.org/forums/index.php/mv/msg/1071310/1711671/#msg_1711671
17. How I can send feedback from the IDE
]]>Yordan Pavlov2015-10-19T08:13:47-00:00Re: Dirigible CodeWeek Workshop - Feedback
https://www.eclipse.org/forums/index.php/mv/msg/1071310/1711781/#msg_1711781
18. All links from http://dirigible.eclipse.org open in the same window/tab!
19. Context menu doesn't work in Safari
20. Although I selected package for my datastructure, in the end of the wizard I had to select again
21. Table names are shared
22. null [null] null in the Database View
23. IN the Database View - Which is my schema. Update the example
24. Menu items in the example are outdated; wrong names e.g. Entity Service JS -
25. HTTP Status 500 - ReferenceError: "exports" is not defined. I cannot preview *_lib.js. See above message that I also see in the preview instead of human readable message
26. "Generate" shall be up in the context menu]]>Tsvetan Stoyanov2015-10-19T15:17:09-00:00Re: Dirigible CodeWeek Workshop - Feedback
https://www.eclipse.org/forums/index.php/mv/msg/1071310/1711955/#msg_1711955
- Presentation for Students
- Presentation for Business
- Presentation for Use-Cases
- Presentation for Architects
- Presentation for Plug-in Developers
- etc...]]>Yordan Pavlov2015-10-20T12:10:33-00:00
