However, I was unable to deploy the xpdl on the browser modeler. Also while testing the UI mashup application inside the process, the structured data was not getting populated on the angular Ui page showDispute.html.
Could you please help me out in this?
Ajay]]>Ajay KS2015-10-06T12:22:22-00:00Re: UI Mashup Example
https://www.eclipse.org/forums/index.php/mv/msg/1070923/1711037/#msg_1711037
You can refer below example:
-RajKumar]]>Rajkumar Dangi2015-10-12T13:40:35-00:00Re: UI Mashup Example
https://www.eclipse.org/forums/index.php/mv/msg/1070923/1711038/#msg_1711038
Thanks for the example. I will go through it.
