!ENTRY org.eclipse.m2e.logback.appender 2 0 2015-05-18 09:30:10.373
!MESSAGE Failure to transfer org.apache.maven.archetypes:maven-archetype-webapp/maven-metadata.xml from repo.maven.apache.org/maven2 was cached in the local repository, resolution will not be reattempted until the update interval of central has elapsed or updates are forced. Original error: Could not transfer metadata org.apache.maven.archetypes:maven-archetype-webapp/maven-metadata.xml from/to central (repo.maven.apache.org/maven2): Connection refused: connect
!ENTRY org.eclipse.m2e.logback.appender 2 0 2015-05-18 09:30:13.259
!ENTRY org.eclipse.m2e.core 4 -1 2015-05-18 09:30:13.329
!MESSAGE Could not resolve archetype org.apache.maven.archetypes:maven-archetype-webapp:RELEASE from any of the configured repositories.
!STACK 1
org.eclipse.core.runtime.CoreException: Could not resolve artifact org.apache.maven.archetypes:maven-archetype-webapp:pom:RELEASE
at org.eclipse.m2e.core.internal.embedder.MavenImpl$5.call(MavenImpl.java:769)
at org.eclipse.m2e.core.internal.embedder.MavenImpl$5.call(MavenImpl.java:1)
at org.eclipse.m2e.core.internal.embedder.MavenExecutionContext.executeBare(MavenExecutionContext.java:166)
at org.eclipse.m2e.core.internal.embedder.MavenExecutionContext.execute(MavenExecutionContext.java:109)
at org.eclipse.m2e.core.internal.embedder.MavenExecutionContext.execute(MavenExecutionContext.java:96)
at org.eclipse.m2e.core.internal.embedder.MavenImpl.resolve(MavenImpl.java:736)
at org.eclipse.m2e.core.internal.embedder.MavenImpl.resolve(MavenImpl.java:713)
at org.eclipse.m2e.core.internal.project.ProjectConfigurationManager.resolveArchetype(ProjectConfigurationManager.java:829)
at org.eclipse.m2e.core.internal.project.ProjectConfigurationManager.createArchetypeProjects0(ProjectConfigurationManager.java:743)
at org.eclipse.m2e.core.internal.project.ProjectConfigurationManager$5.call(ProjectConfigurationManager.java:719)
at org.eclipse.m2e.core.internal.project.ProjectConfigurationManager$5.call(ProjectConfigurationManager.java:1)
at org.eclipse.m2e.core.internal.embedder.MavenExecutionContext.execute(MavenExecutionContext.java:142)
at org.eclipse.m2e.core.internal.embedder.MavenImpl.execute(MavenImpl.java:1348)
at org.eclipse.m2e.core.internal.project.ProjectConfigurationManager.createArchetypeProjects(ProjectConfigurationManager.java:717)
at org.eclipse.m2e.core.ui.internal.wizards.MavenProjectWizard$5.doCreateMavenProjects(MavenProjectWizard.java:244)
at org.eclipse.m2e.core.ui.internal.wizards.AbstactCreateMavenProjectJob$1.doCreateMavenProjects(AbstactCreateMavenProjectJob.java:46)
at org.eclipse.m2e.core.ui.internal.wizards.AbstractCreateMavenProjectsOperation.run(AbstractCreateMavenProjectsOperation.java:62)
at org.eclipse.m2e.core.ui.internal.wizards.AbstactCreateMavenProjectJob.runInWorkspace(AbstactCreateMavenProjectJob.java:50)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Contains: Failed to resolve version for org.apache.maven.archetypes:maven-archetype-webapp:pom:RELEASE: Could not find metadata org.apache.maven.archetypes:maven-archetype-webapp/maven-metadata.xml in local (D:\Users\dlefebvre\.m2\repository)
org.eclipse.aether.resolution.VersionResolutionException: Failed to resolve version for org.apache.maven.archetypes:maven-archetype-webapp:pom:RELEASE: Could not find metadata org.apache.maven.archetypes:maven-archetype-webapp/maven-metadata.xml in local (D:\Users\dlefebvre\.m2\repository)
at org.apache.maven.repository.internal.DefaultVersionResolver.resolveVersion(DefaultVersionResolver.java:312)
at org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:318)
at org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifacts(DefaultArtifactResolver.java:262)
at org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifact(DefaultArtifactResolver.java:239)
at org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveArtifact(DefaultRepositorySystem.java:295)
at org.eclipse.m2e.core.internal.embedder.MavenImpl$5.call(MavenImpl.java:746)
Caused by: org.eclipse.aether.transfer.MetadataNotFoundException: Could not find metadata org.apache.maven.archetypes:maven-archetype-webapp/maven-metadata.xml in local (D:\Users\dlefebvre\.m2\repository)
at org.eclipse.aether.internal.impl.DefaultMetadataResolver.resolve(DefaultMetadataResolver.java:260)
at org.eclipse.aether.internal.impl.DefaultMetadataResolver.resolveMetadata(DefaultMetadataResolver.java:218)
at org.apache.maven.repository.internal.DefaultVersionResolver.resolveVersion(DefaultVersionResolver.java:250)
... 26 more
!SUBENTRY 1 org.eclipse.m2e.core 4 -1 2015-05-18 09:30:13.334
!MESSAGE Could not resolve artifact org.apache.maven.archetypes:maven-archetype-webapp:pom:RELEASE
!SUBENTRY 2 org.eclipse.m2e.core 4 -1 2015-05-18 09:30:13.334
!MESSAGE Failed to resolve version for org.apache.maven.archetypes:maven-archetype-webapp:pom:RELEASE: Could not find metadata org.apache.maven.archetypes:maven-archetype-webapp/maven-metadata.xml in local (D:\Users\dlefebvre\.m2\repository)
!STACK 0
... 26 more
