https://download.eclipse.org/datatools/updates/]]>Ed Merks2023-06-05T12:36:48-00:00Re: adding data tools to IDE
https://www.eclipse.org/forums/index.php/mv/msg/1112659/1859393/#msg_1859393
This, for example, is an update site:
Data Tools are also available in the release train repository, e.g., https://download.eclipse.org/releases/2022-12 which is generally already in your list of choices.]]>Ed Merks2023-06-05T07:00:10-00:00adding data tools to IDE
https://www.eclipse.org/forums/index.php/mv/msg/1112659/1858023/#msg_1858023
>Help>Install New Software... and paste https://download.eclipse.org/datatools/downloads/1.11/ in the form 's "Work with" line, and click "Add..." Button just to get alerted that no software site was found at that link.
but how am I supposed to get equipped with DTP?
Yours`
sehrguey]]>Sehrguey Ogoltsoff2023-03-11T14:10:15-00:00Packages not showing in Oracle database connected through Eclipse
https://www.eclipse.org/forums/index.php/mv/msg/1111929/1855838/#msg_1855838
Sunil Sahoo2022-11-07T12:31:47-00:00Data source explore does not show schema
https://www.eclipse.org/forums/index.php/mv/msg/1110987/1853041/#msg_1853041
John Bushey2022-06-15T15:34:32-00:00Re: Delete/Remove Database Connection Drivers
https://www.eclipse.org/forums/index.php/mv/msg/1103978/1849622/#msg_1849622
Open Eclipse -> click on search button (or cmd+3 on Mac) -> type in "manage driver" -> click on "Preferences (data Management > Connectivity > Driver Definitions)" -> choose the drivers you don't need and remove them]]>Nadezhda Li2022-01-27T07:24:31-00:00Re: running recorded http script, no session
https://www.eclipse.org/forums/index.php/mv/msg/93/1846915/#msg_1846915
2021-10-09T00:44:32-00:00Re: running recorded http script, no session
https://www.eclipse.org/forums/index.php/mv/msg/36/1846907/#msg_1846907
2021-10-09T00:41:24-00:00Re: Set a XML DataSource Programmatically
https://www.eclipse.org/forums/index.php/mv/msg/75/1846595/#msg_1846595
2021-10-08T22:01:54-00:00How to add new button
https://www.eclipse.org/forums/index.php/mv/msg/1106957/1838014/#msg_1838014
https://bestfreeporn.me/ .
Ricky's words kept echoing around in my head. I thought about how it would feel to be fucked by all the boys, one after another. Again, another set of wet panties! I really needed some way to relieve the pressure that was building in my pussy. I remembered that Mom had a thing hidden in the bottom of the closet in a box. Mom was still downstairs with Barbara. John was still at the fort. I was trying to figure out a way to sneak into Mom's room when she called up the stairs and said that she and Barbara were going to the store and wanted to know if I wanted to go. I said no I would just watch something on TV. When she drove off I quickly went to her closet and found the box. I hurried to the bathroom and looked at what was in the box. It was a stiff thing (I later learned it was called a dildo) shaped like a cock and it was about 8 inches long and thicker than Ricky's cock. I read the instructions and they said if you turned the base, the tip would vibrate cool! I turned the base and nothing happened. I re-read the instructions and they said to check the batteries. It took two c-size batteries and both were missing. I ran into John's room and as luck would have it I found two c-size batteries. I inserted the batteries and turned the base. The head started vibrating. The instructions said it could be placed against my clitoris or inserted into my vagina way cool! It also said it could be inserted in my anus - Not cool! Since nobody was home I decided to see how it felt. I pulled off my panties and set on the commode lid. I spread my legs apart and placed the vibrating tip on my clitoris and almost fell off the commode. The pleasure I felt went through my whole body. Liquid was flowing out of my pussy. I move the tip to my pussy and again the pleasure was intense. I carefully started to insert it into my pussy and moved it in and out, going deeper each time. I bumped up against my cherry. Suddenly the door open and there stood John with his cell phone. I was so startled that I shoved the thing deep into my pussy. I felt my cherry burst and the pain was terrific. I yelled out in pain and John stopped filming. I was crying and when I looked down my pussy juices were mixed with little blood. John just stood there in shock. I told him to get the hell out of there and he ran from the bathroom.
I went down to Mom's bathroom and got one of her tampons. I then went in search of John and when I found him I intended to kick his balls up around his neck. I knew he had taken the cell phone to show his buddies of me using the dildo and busting my cherry. I was in pain and mad as hell! I march right up to the fort door and kicked it open. If I had not been so much in pain I would have laughed out loud. There they were with one hand on their cocks and the other passing the cell phone around. I said, "give me the damn phone." John started to and Matt grabbed it out of his hand. I looked at Matt and said, "give me the goddamn phone, or I was going to kick him in the balls." He quickly gave me the phone. I found the video John had taken of me with the dildo and deleted it. I threw the phone at John and stormed off https://hotmyfreecams.com .
Later as I laid on my bed crying, John knocked on the door and asked if he could come in? He wanted to say that he was sorry that he took pictures of me and that he had shown them to the other boys. He was really sorry that he caused me to bust my cherry. He was so sad looking that I said that I forgave him. I also said that the next time he took pictures of me we would do it together. The look of shock on his face was priceless. I said I was very sore, but in a few days it would pass and I would probably use the dildo again. He was like a deer in the headlights. I don't think his eyes could have gotten any wider. I also told him that I had watched them and heard what they had talked about in the fort. I then dropped my bombshell. I told him to tell the boys I was thinking of letting them fuck me, one after another in the fort, but had not made up my mind. John looked at me and said did that mean him too? I said yes! He ran from my room and out the front door like a rocket.]]>Betsey McMullin2021-02-13T06:47:18-00:00
