Forum is freezed
https://www.eclipse.org/forums/index.php/mv/msg/886724/1504803/#msg_1504803
First, because moderator Paul Verest stepped down.
Secondly, because currently eclipse.org website is not optimized for usage in China https://bugs.eclipse.org/bugs/show_bug.cgi?id=437568
If you would like to re-enable and serve as moderator,
create new issue or comment inside
https://bugs.eclipse.org/bugs/show_bug.cgi?id=424938
Paul Verest
2014-12-09T15:24:17-00:00
Eclipse Luna(最新版)
https://www.eclipse.org/forums/index.php/mv/msg/836851/1451608/#msg_1451608
能否解释下都需要下载那些插件,怎么使用?
是否支持Eclipse luna SE和Eclipse luna EE
在Eclipse.org上哪里可以找到,可以的话能否把链接给下,非常感谢。 ]]>
Hou Zhipeng
2014-10-24T03:28:18-00:00
Eclipse for php
https://www.eclipse.org/forums/index.php/mv/msg/821168/1433753/#msg_1433753
但是 FOLLOW 範例設定,一直到 debug 環境時都出現
Zend Debugger extension is not installed
或是
XDebug extension is not installed. Please visit to install it.
但是我在 xdebug 找不到如何安裝的說明
我使用 eclipse for php 套件
kuolung lin
2014-09-29T07:47:59-00:00
Re: 怎么调大luna内存
https://www.eclipse.org/forums/index.php/mv/msg/816841/1429401/#msg_1429401
eclipse [normal arguments] -vmargs -Xmx256M [more VM args]
https://wiki.eclipse.org/FAQ_How_do_I_increase_the_heap_size_available_to_Eclipse%3F
注意
1. Java 8 有相关的变化
2. 如果内存不过,可能安装的插件太多。考虑第安装在二个eclipse]]>
Paul Verest
2014-09-23T07:29:53-00:00
怎么调大luna内存
https://www.eclipse.org/forums/index.php/mv/msg/816841/1428923/#msg_1428923
Yi Leung
2014-09-22T14:47:06-00:00
Firewire 1394相机
https://www.eclipse.org/forums/index.php/mv/msg/781832/1386245/#msg_1386245
最近做了一个关于eclipse打开firewire 1394相机的课题,编程环境mingw,eclipse IDE(c++),opencv
在卡耐基梅隆的网站上可以下载到1394相机驱动和源代码zip文件
现在已经可以实现用驱动打开相机,但是把zip文件解压到eclipse的workspace中会出现很多错误
eclipse已经可以运行hello world和读取指定路径图片等小程序,这就说明了编译环境没有问题,系统的环境变量也没什么问题。
网上查阅了相关资料,都是用软件打开USB相机,打开1394相机的几乎没有,有大神曾经做过类似的东西吗,或者用Visual studio VC编译过也差不多的.
求指导
感谢]]>
hauming Chen
2014-06-16T06:33:16-00:00
Re: luaeclipse
https://www.eclipse.org/forums/index.php/mv/msg/637195/1343327/#msg_1343327
jack jose
2014-05-09T08:31:27-00:00
Re: Eclipse北京大会
https://www.eclipse.org/forums/index.php/mv/msg/646849/1335456/#msg_1335456
Thanh Nguyen
2014-05-06T01:53:59-00:00
QQ群及例外的交流方式
https://www.eclipse.org/forums/index.php/mv/msg/659834/1257129/#msg_1257129
Eclipse开发QQ群 374545615 Eclipse平台,RCP,插件开发讨论。
如果在Eclipse论坛看不见自己的论坛帖子, 请在321486747 QQ群说。
还有什么好的Eclipse网站,媒体,资料等等?]]>
Paul Verest
2014-02-26T05:09:16-00:00
Eclipse北京大会
https://www.eclipse.org/forums/index.php/mv/msg/646849/1242908/#msg_1242908
https://wiki.eclipse.org/Eclipse_DemoCamps_Luna_2014/Beijing] 邀请Eclipse专业人来讲在6月活动。主题应该对Eclipse有关系:IDE,插件,Hudson, vert.x, M2M 或者例外的 Eclipse基金会项目。欢迎欢迎来分享。
来宾,讲师都要报名在[https://yoopay.cn/event/31347339?ref=eclipse-forum ]]]>
Paul Verest
2014-02-10T08:43:04-00:00
