Eclipse Community ForumsRe: Gemini Blueprint future and compatibility with Java 17 and Spring 6?
https://www.eclipse.org/forums/index.php/mv/msg/1114136/1863123/#msg_1863123
Marek Tokarski2024-01-17T08:12:22-00:00Gemini Blueprint future and compatibility with Java 17 and Spring 6?
https://www.eclipse.org/forums/index.php/mv/msg/1114136/1862608/#msg_1862608
Vaclav Haisman2023-12-14T08:24:25-00:00https://download.eclipse.org/gemini/mvn
https://www.eclipse.org/forums/index.php/mv/msg/1112828/1858530/#msg_1858530
Thanks in adavance]]>Ralf Mollik2023-04-06T09:19:44-00:00Will Gemini Blueprint release a new version in the near future
https://www.eclipse.org/forums/index.php/mv/msg/1112025/1856158/#msg_1856158
fan zhang2022-11-23T16:50:55-00:00Re: JNDI Values not accessible on Gemini blueprint Spring Configuration running on Tomcat
https://www.eclipse.org/forums/index.php/mv/msg/1111367/1854216/#msg_1854216
If i Move my JNDI-Lookups from xml into my Spring-Configuration-class then i can change the clasloader in init like this:
Thread.currentThread().setContextClassLoader(this.getClass().getClassLoader());
I can define my JDNI Values in server.xml link them in context.xml and use them in my web.xml.
In my launch.ini i use the parent classloader fwk so the JNDI configuration is passed to the OSGI-Container.
My Application-Bundles can read those values for example in Bundle-Activator:
String xxx= InitialContext.doLookup("java:comp/env/xxx"); or
String xxx= new InitialContext().lookup("java:comp/env/xxx");
Invoked from Gemini in BlueprintExtenderThread i can't access those values.
<jee:jndi-lookup id="xxx" jndi-name="java:comp/env/xxx" />
fails.
The classloaders are different in Bundle-Activator and BlueprintExtenderThread.
How can i access my JNDI configuration with gemini blueprint?]]>Christian Meister2022-08-05T09:21:49-00:00How can you expose a bean as an osgi service via java config annotation?
https://www.eclipse.org/forums/index.php/mv/msg/1108619/1843553/#msg_1843553
but what does the equivalent of osgi:service]]>Garry Boyce2021-08-05T17:24:34-00:00EntityManagerFactoryBuilder not found in Test
https://www.eclipse.org/forums/index.php/mv/msg/1108165/1842041/#msg_1842041
I've just tried to run org.eclipse.gemini.jpa.test.basic.TestEMFBuilderService, but it fails because no EntityManagerFactoryBuilder was found (as a service). This is because of no class registers such a service. So, the question is: How could the test run?
Currently, I try to migrate the DbAccess and JPA sources to Java 11. It compiles, but I can't run any of the tests. Would be great if anyone here could give me a hint.
Ralf.]]>Ralf Heydenreich2021-06-08T06:13:33-00:00Status of Gemini DbAccess
https://www.eclipse.org/forums/index.php/mv/msg/1108069/1841715/#msg_1841715
Ralf.]]>Ralf Heydenreich2021-05-26T13:04:43-00:00Re: WAB not reacheable after deployment on Gemini WEB
https://www.eclipse.org/forums/index.php/mv/msg/1094439/1841516/#msg_1841516
The problem seems like Gemini Web (when deployed under the servlet bridge) still starts its own Tomcat server instance listening to a TCP port (8080 default).
In your case, as you are running Tomcat on the same TCP port than the Gemini Web's default (8080) probably Gemini Web is not properly started up due the port number conflict. So you must change one of them: the Host Tomcat or the Gemini Web (embedded Tomcat) TCP port.
In the initial part of this recorded session (animated gif)...
...Gemini Web is installed under the Servlet Bridge that is reachable at:
As you see, this is useless because the user logged in against application deployed in the host Tomcat (http://localhost:2990/jira), so the user session is missing when you access via Gemini Web (http://localhost:8080)
If you are interested, the second part of the "video", it shows the same WAB example running on PAX-WEB under the same servlet bridge, that almost works: the WAB is detected and the servlet registered (like it happens with Gemini Web) but the Web-ContextPath ignored because a bug.
It would be nice if Gemini Web supports the Servlet Bridge.
This might seem a bit strange architecture but it would be really useful for the real World where reality overcomes software architects' imagination.
Pablo]]>Pablo eltrán2021-05-19T17:22:11-00:00
