Home » Eclipse Projects » BIRT » please help increase java heap size
please help increase java heap size [message #1159487] Mon, 28 October 2013 15:17 Go to next message
Gibran Shah is currently offline Gibran ShahFriend
Member
I dealing with a rather large report that is testing the limits of the Java heap size. It's crashing a lot because it keep running out of memory. I've been told that I can increase the heap size. When I googled this, I came up with this:
java -xms__m _xmx__m
where __ means the size of the memory.
This is something I could do on a command line when running a java program, but my question is: how can I do this in Eclipse? I've looked for a setting somewhere where I can plug these parameters in--I've looked in preferences, properties, and elsewhere--but I can't find a place to do it.
Can someone please help me find out where this is done?
Re: please help increase java heap size [message #1160390 is a reply to message #1159487] Tue, 29 October 2013 05:20 Go to previous message
Gupta K P K is currently offline Gupta K P KFriend
Change the parameters in eclipse.ini(eclipse directory) and save it(-Xms__m -Xmx__m)before opening eclipse. You can give these parameters under run>runconfiguration>arguments>VMarguments
Previous Topic:please help with output formats
Next Topic:BIRT 3.7.2 or later version working on WebSphere 8
Current Time: Sat Jun 23 06:04:22 GMT 2018
Powered by FUDForum. Page generated in 0.02493 seconds
