Home » Eclipse Projects » JFace » Caching problem in ObservableCollectionTreeContentProvider.getOrCreateNode(Object,boolean)
Caching problem in ObservableCollectionTreeContentProvider.getOrCreateNode(Object,boolean) [message #1159235] Mon, 28 October 2013 11:36
Erdal Karaca is currently offline Erdal KaracaFriend
I have the following scenario:
The ObservableCollectionTreeContentProvider caches the same WritableList twice and on dispose of the Viewer, this same WritableList will be disposed twice which will lead to the following exception:
org.eclipse.core.runtime.AssertionFailedException: assertion failed: Getter called on disposed observable org.eclipse.core.databinding.observable.list.WritableList@1d57cdf
	at org.eclipse.core.runtime.Assert.isTrue(Assert.java:110)
	at org.eclipse.core.databinding.observable.ObservableTracker.getterCalled(ObservableTracker.java:252)
	at org.eclipse.core.databinding.observable.list.ObservableList.getterCalled(ObservableList.java:241)
	at org.eclipse.core.databinding.observable.list.ObservableList.hashCode(ObservableList.java:92)
	at java.util.HashMap.removeEntryForKey(Unknown Source)
	at java.util.HashMap.remove(Unknown Source)
	at org.eclipse.jface.internal.databinding.viewers.ObservableCollectionTreeContentProvider$TreeNode.dispose(ObservableCollectionTreeContentProvider.java:491)
	at org.eclipse.jface.internal.databinding.viewers.ObservableCollectionTreeContentProvider$TreeNode.access$0(ObservableCollectionTreeContentProvider.java:489)
	at org.eclipse.jface.internal.databinding.viewers.ObservableCollectionTreeContentProvider.inputChanged(ObservableCollectionTreeContentProvider.java:137)
	at org.eclipse.jface.databinding.viewers.ObservableListTreeContentProvider$Impl.inputChanged(ObservableListTreeContentProvider.java:55)
	at org.eclipse.jface.databinding.viewers.ObservableListTreeContentProvider.inputChanged(ObservableListTreeContentProvider.java:203)
	at org.eclipse.jface.viewers.ContentViewer.handleDispose(ContentViewer.java:171)
	at org.eclipse.jface.viewers.StructuredViewer.handleDispose(StructuredViewer.java:2328)
	at org.eclipse.jface.viewers.ContentViewer$2.widgetDisposed(ContentViewer.java:214)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:123)
Internally, org.eclipse.jface.internal.databinding.viewers.ObservableCollectionTreeContentProvider.elementNodes is backed by a HashMap which uses the hashCode() method of the object to be put. Initially, the input of the viewer is an empty WritableList. "Later", the WritableList will be populated by user code and a Viewer.refresh() will be done which makes the WritableList to be added twice as this time the WritableList is not empty and the hashCode() differs.
Bug or wrong usage of the API?
Previous Topic:Observable label provider for EMF elements ?
Next Topic:Listen to disposing of a binding?
Current Time: Wed Apr 25 18:39:41 GMT 2018
Powered by FUDForum. Page generated in 0.01976 seconds
