Home » Eclipse Projects » Eclipse 4 » Deleting a part from a model
Deleting a part from a model [message #1067452] Mon, 08 July 2013 19:03 Go to next message
Patrick Rusk is currently offline Patrick RuskFriend
Member
I have a situation where I use the PartService's createPart() method to create a part from a PartDescriptor. The PartDescriptor indicates that the part is "multiple", "closeable", and "dirtyable".
My problem is that when I then close the part, I see in the workbench.xmi that there is still an entry for the part, with toBeRendered="false". That orphaned entry isn't really doing me any good because I don't want to retrieve it again.
Is there a way I can tell the model to remove the part entirely when it is closed? I'm sure there must be, but I can't find the API in either the EPartService or EModelService.
Thank you.
Re: Deleting a part from a model [message #1067453 is a reply to message #1067452] Mon, 08 July 2013 19:09 Go to previous messageGo to next message
Member
My, how often the answer comes just after posting to a forum....
Calling setParent(null) on the part did the trick.
Re: Deleting a part from a model [message #1067457 is a reply to message #1067453] Mon, 08 July 2013 19:29 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
The real solution is to tag the part with "removeOnHide" and the
framework will remove the instance from the model when closed.
Tom
Re: Deleting a part from a model [message #1067515 is a reply to message #1067457] Tue, 09 July 2013 08:08 Go to previous messageGo to next message
Phill Perryman is currently offline Phill PerrymanFriend
I put removeOnHide into eclipse help (F1) but it finds no matches. Is there a list of these tags somewhere. I am assuming I just add it to the Tags on the supplementary tag of the part descriptor.
Re: Deleting a part from a model [message #1067528 is a reply to message #1067515] Tue, 09 July 2013 08:45 Go to previous messageGo to next message
It is on the EPartService. I currently don't know if this is documented
in the wiki else this should be done there. Naturally also the tooling
should know the tags available - you should file a bug against it unless
there's already one.
Tom
Re: Deleting a part from a model [message #1067565 is a reply to message #1067528] Tue, 09 July 2013 11:09 Go to previous message
https://bugs.eclipse.org/393870
M.
Previous Topic:Exception Workbench has not been created yet
Next Topic:Add ControlContribution to Coolbar
Current Time: Thu Apr 26 21:23:05 GMT 2018
Powered by FUDForum. Page generated in 0.01674 seconds
