Home » Eclipse Projects » Eclipse 4 » Exception Workbench has not been created yet(With Eclipse 4 Application)
Exception Workbench has not been created yet [message #1067414] Mon, 08 July 2013 14:43 Go to next message
AIT YAHIA Idir is currently offline AIT YAHIA IdirFriend
Member
I have created an RCP application with E4 Application model, it's work fine but when a i try to get some Workbench ressources i get a java.lang.IllegalStateException: Workbench has not been created yet.
For example when calling
PlatformUI.getWorkbench().getDisplay();
from what I read this is due to the lazy instantiation, Can someone tell me how to instantiate the workbench, I need to impélmentation some selection Dialog
Trace
org.eclipse.e4.core.di.InjectionException: java.lang.IllegalStateException: Workbench has not been created yet.
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:243)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:224)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
	at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:167)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:850)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:743)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:727)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:662)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:162)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: java.lang.IllegalStateException: Workbench has not been created yet.
	at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:93)
	at org.eclipse.ui.dialogs.FilteredItemsSelectionDialog.createViewMenu(FilteredItemsSelectionDialog.java:549)
	at org.eclipse.ui.dialogs.FilteredItemsSelectionDialog.createHeader(FilteredItemsSelectionDialog.java:478)
	at org.eclipse.ui.dialogs.FilteredItemsSelectionDialog.createDialogArea(FilteredItemsSelectionDialog.java:655)
	at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java:775)
	at org.eclipse.jface.window.Window.create(Window.java:432)
	at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1104)
	at org.eclipse.ui.dialogs.SelectionStatusDialog.create(SelectionStatusDialog.java:153)
	at org.eclipse.ui.dialogs.FilteredItemsSelectionDialog.create(FilteredItemsSelectionDialog.java:355)
	at org.eclipse.jface.window.Window.open(Window.java:791)
	at dz.iaityahia.cieptalcars.matresorerie.handlers.ExportToExcelAction.execute(ExportToExcelAction.java:17)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	... 33 more
Re: Exception Workbench has not been created yet [message #1463466 is a reply to message #1067414] Thu, 06 November 2014 15:40 Go to previous messageGo to next message
Patty Eilers is currently offline Patty EilersFriend
Did you ever get an answer to this or figure out how to resolve it? I am having the same issue and would like to know how you worked around it. Much appreciated....
Re: Exception Workbench has not been created yet [message #1470331 is a reply to message #1463466] Wed, 12 November 2014 08:55 Go to previous messageGo to next message
Olivier Prouvost is currently offline Olivier ProuvostFriend
The PlatformUI.getWorkbench() is a Eclipse 3.x method. If you are in a pure E4 application, you must not depend on org.eclipse.ui and you will not be able to call this method.
If you need to get the Display or current IWorkbench (which would be an E4 workbench), you must inject it where you need it, or you can get the Display using Display.getCurrent().
icon5.gif  Re: Exception Workbench has not been created yet [message #1695929 is a reply to message #1470331] Wed, 20 May 2015 11:21 Go to previous messageGo to next message
Crenguta Manea is currently offline Crenguta ManeaFriend
I am injecting the E4 Workbench (org.eclipse.e4.ui.workbench), but I still get a "Workbench has not been created yet". Is there anything else you have to do other than injecting it?
Thanks.
Re: Exception Workbench has not been created yet [message #1696001 is a reply to message #1695929] Thu, 21 May 2015 05:57 Go to previous message
Dirk Fauth is currently offline Dirk FauthFriend
The question is, when are you trying to inject? Looks like you are trying to early in the startup process.
Previous Topic:Discouraged Access
Next Topic:Deleting a part from a model
Current Time: Mon Apr 23 05:57:04 GMT 2018
Powered by FUDForum. Page generated in 0.01840 seconds
