Home » Eclipse Projects » Eclipse 4 » Discouraged Access
Discouraged Access [message #1067408] Mon, 08 July 2013 14:31 Go to next message
Phill Perryman is currently offline Phill PerrymanFriend
Kepler 64 bit windows
I am following Lars' tutorial (book and article from 4 days ago have same code) and adding a popup menu. However when I add the import
import org.eclipse.e4.ui.workbench.swt.modeling.EMenuService;
I get
Description Resource Path Location Type
Discouraged access: The type EMenuService is not accessible due to restriction on required library C:\eclipse\Kepler64\eclipse\plugins\org.eclipse.e4.ui.workbench.swt_0.12.0.v20130517-0139.jar HomePage.java /swb3/src/swb3/parts line 20 Java Problem
Has the popup menu registration process changed
Re: Discouraged Access [message #1067527 is a reply to message #1067408] Tue, 09 July 2013 08:48 Go to previous messageGo to next message
Sopot Cela is currently offline Sopot CelaFriend
http://www.eclipse.org/forums/index.php/mv/msg/287549/793636/#msg_793636
Re: Discouraged Access [message #1067568 is a reply to message #1067527] Tue, 09 July 2013 11:30 Go to previous message
Thanks, I will tag them as @SuppressWarnings("restriction") and wait for them to be published.
Previous Topic:[Kepler] Cannot resolve org.eclipse.e4.ui.model.application.*
Next Topic:Exception Workbench has not been created yet
Current Time: Fri May 25 03:38:41 GMT 2018
Powered by FUDForum. Page generated in 0.01414 seconds
