Home » Eclipse Projects » Eclipse 4 » [Kepler] Cannot resolve org.eclipse.e4.ui.model.application.*(Project migration from Juno to Kepler)
[Kepler] Cannot resolve org.eclipse.e4.ui.model.application.* [message #1067403] Mon, 08 July 2013 14:22 Go to next message
Jack Mising name is currently offline Jack Mising nameFriend
Hi All,
I am trying to migrate a project I am working on in Juno to Kepler. I have the RCP edition of Kepler and the E4 Tools 'Stream Integration Build' installed.
However, my project will not build. I get an error marked on the following :-
menuService.registerContextMenu(treeViewer.getControl(), id);
The error is :-
The type org.eclipse.e4.ui.model.application.ui.menu.MPopupMenu cannot be resolved. It is indirectly referenced from required .class files
If I comment out that line, other parts of the build break as it then cannot resolve org.eclipse.e4.ui.model.application.MApplication
There is clearly a plugin somewhere that I have not got installed but I don't see any dependency errors and I can't see anything obvious that I've missed installing in Kepler than was in Juno.
Can anyone point me in a direction to look?
TIA,
Jack
Re: [Kepler] Cannot resolve org.eclipse.e4.ui.model.application.* [message #1067406 is a reply to message #1067403] Mon, 08 July 2013 14:28 Go to previous messageGo to next message
Sopot Cela is currently offline Sopot CelaFriend
Add org.eclipse.e4.ui.mode.workbench to your dependencies in the manifest.
Re: [Kepler] Cannot resolve org.eclipse.e4.ui.model.application.* [message #1067413 is a reply to message #1067406] Mon, 08 July 2013 14:36 Go to previous message
That sorted it.
Thanks!
Jack
Previous Topic:keybindings and bindingcontext
Next Topic:Discouraged Access
Current Time: Mon May 21 15:15:36 GMT 2018
Powered by FUDForum. Page generated in 0.02737 seconds
