Home » Eclipse Projects » Rich Client Platform (RCP) » [Kepler] saveState and restoreState of WorkbenchAdvisor not called
[Kepler] saveState and restoreState of WorkbenchAdvisor not called [message #1067398] Mon, 08 July 2013 13:59 Go to next message
Cedric Moonen is currently offline Cedric MoonenFriend
I recently upgraded my RCP application from Indigo to Kepler but I'm not able to save and restore some custom information about my application.
I have put breakpoints in the saveState and restoreState (overridden) methods of my ApplicationWorkbenchAdvisor but those breakpoints are never reached.
I made sure that the saveStateAndRestore flag is set to true in the initialize method:
	public void initialize(IWorkbenchConfigurer configurer) {
		super.initialize(configurer);
		configurer.setSaveAndRestore(true);
Is this a bug introduced recently or am I missing something ?
Thank you
C├ędric
Re: [Kepler] saveState and restoreState of WorkbenchAdvisor not called [message #1067571 is a reply to message #1067398] Tue, 09 July 2013 11:44 Go to previous message
I had a look at the Eclipse source code for the Workbench and from Indigo to Kepler, saving workbench state is completely different.
In Indigo:
	private IStatus saveState(IMemento memento) {
		MultiStatus result = new MultiStatus(PlatformUI.PLUGIN_ID, IStatus.OK,
				WorkbenchMessages.Workbench_problemsSaving, null);
		// Save the version number.
		memento.putString(IWorkbenchConstants.TAG_VERSION, VERSION_STRING[1]);
		// Save how many plug-ins were loaded while restoring the workbench
		if (progressCount != -1) {
			memento.putInteger(IWorkbenchConstants.TAG_PROGRESS_COUNT,
					progressCount);
		// Save the advisor state.
		IMemento advisorState = memento
				.createChild(IWorkbenchConstants.TAG_WORKBENCH_ADVISOR);
		result.add(getAdvisor().saveState(advisorState));
		// Save the workbench windows.
		IWorkbenchWindow[] windows = getWorkbenchWindows();
		for (int nX = 0; nX < windows.length; nX++) {
			WorkbenchWindow window = (WorkbenchWindow) windows[nX];
			IMemento childMem = memento
					.createChild(IWorkbenchConstants.TAG_WINDOW);
			result.merge(window.saveState(childMem));
		result.add(getEditorHistory().saveState(
				memento.createChild(IWorkbenchConstants.TAG_MRU_LIST)));
		return result;
So there you can see that the workbench advisor gets invoked to save the state.
In Kepler:
	private IStatus saveWorkbenchState(IMemento memento) {
		// TODO: Currently we store the editors history only. Add more if needed
		return result;
Where did the rest of the code suddenly disappear ?? Why was everything removed there, except for editors MRU list ? Or did I miss something ?
Previous Topic:SavePerspectiveAction does not work in eclipse 4.2
Next Topic:IWorkbenchPage.getPartState() always returns RESTORED
Current Time: Sat Apr 21 21:30:58 GMT 2018
Powered by FUDForum. Page generated in 0.02108 seconds
