Home » Modeling » OCL » Need help in constraint syntax
Need help in constraint syntax [message #1046090] Sun, 21 April 2013 10:27 Go to next message
Walid Ban is currently offline Walid BanFriend
Member
Using Papyrus v0.10 (Eclipse Kepler Version), I added OCL constraints in my profile but the OCL Essential editor show a syntax error that i didn't understand, here's an example:
self.send -> forAll (o | o.oclIsKindOf (ObjectBase) or o.oclIsKindOf (ObjectMultiviews))
(ObjectBase and ObjectMultiviews are two Life Line stereotypes)
The Essential Editor considers "send" an unresolved property.
Do you have any idea what i have to modify in the constraint to resolve this error?
Thank you
Re: Need help in constraint syntax [message #1046286 is a reply to message #1046090] Sun, 21 April 2013 17:48 Go to previous message
Ed Willink is currently offline Ed WillinkFriend
"The Essential Editor considers "send" an unresolved property. "
seems like a very accurate diagnosis; send is not resolved.
Use the hovertext on self to see if it's the type you intended. The type
is defined by the context type in the Properties View.
Use the completion assist following "self." to see what might be available.
Kepler has not been release so there is no definitive Kepler version.
You need to indicate which milestyone/nightly/... builds you are using.
Ed Willink
On 21/04/2013 11:27, Walid Ban wrote:
> Hi, Using Papyrus v0.10 (Eclipse Kepler Version), I added OCL
> (ObjectMultiviews))
> (ObjectBase and ObjectMultiviews are two Life Line stereotypes) The
> resolve this error?
> Thank you
> Regards
Previous Topic:OMG OCL specification Issue Tracking
Next Topic:HOW TO PARSE UML2.1 class diagram with OCL?
Current Time: Sat Apr 21 17:34:10 GMT 2018
Powered by FUDForum. Page generated in 0.01837 seconds
