Home » Modeling » Papyrus » Information on model explorer customization
Information on model explorer customization [message #1045594] Sat, 20 April 2013 14:23 Go to next message
Dieter Van Eessen is currently offline Dieter Van EessenFriend
Is there a place where I can find documentation on the model explorer browser customization? I've been playing a bit with it by removing, adding and combining several customizations... But it's still cloudy to figure out which combination of browser customizations in which order will provide the desired model explorer configuration.
Mainly I'd like a way to navigate fast through an imported model library with nested classifiers (the model contains multiple (5-7) levels) and specifying types takes a while... The 'SimpleUml' browsercustomization seems to make the 'nestedClassifier' levels dissappear (1 less arrow to click) but it also drops the possibility to navigate in imported packages...
kind regards,
Dieter
[Updated on: Sat, 20 April 2013 14:24]
Report message to a moderator
Re: Information on model explorer customization [message #1046676 is a reply to message #1045594] Mon, 22 April 2013 08:11 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille LetavernierFriend
Papyrus relies on EMF Facet "uiCustom" models to customize the ModelExplorer ("BrowserCustomization"). This is the same mechanism as described in the MoDisco documentation:
http://download.eclipse.org/modeling/mdt/modisco/nightly/doc/org.eclipse.modisco.doc/
http://download.eclipse.org/modeling/mdt/modisco/nightly/doc/org.eclipse.modisco.infrastructure.doc/mediawiki/custom/user.html
EMF Facet is a project initially created from a subset of MoDisco. The documentation is the same, but we really rely on the EMF Facet component. You may need to activate the "EMF Facet" capability (And disable the MoDisco one) to avoid confusion (Window > Preferences > General > Capabilities)
Regarding the Simple UML customization, it's still in development. See:
394937: [Model Explorer] Papyrus shall propose a simplified model explorer view.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=394937
When it is finished, it should become the default customization. Until then, you'll have to apply it manually.
Camille
Camille Letavernier
Re: Information on model explorer customization [message #1050093 is a reply to message #1045594] Fri, 26 April 2013 17:39 Go to previous message
Thanks. The SimpleUML customization is already a great customization. If it will improve even more, I'm looking forward to the result!
Going to explore those uiCustom-files for temporary solutions.
Dieter
[Updated on: Fri, 26 April 2013 17:54]
Previous Topic:Problem with papyrusDiagram extension point on Papyrus 0.9.2
Next Topic:OCL Constraint on all classes ?
Current Time: Wed Jun 20 15:45:09 GMT 2018
Powered by FUDForum. Page generated in 0.01647 seconds
