Home » Newcomers » Newcomers » Unhandled loop exception when moving frames around
Unhandled loop exception when moving frames around [message #1045332] Sat, 20 April 2013 04:38 Go to next message
d grin is currently offline d grinFriend
If I start at my standard java view and then I move one of my open programs to the side (so I can see 2 open programs at once, side to side), and then I click on either of the frames, I get
unhandled event loop exception
Item not added
I then get the following in the event detail's stack trace -
eclipse.buildId=M20130204-1200
java.version=1.7.0_17
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments:  -product org.eclipse.epp.package.jee.product
Command-line arguments:  -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
Error
Sat Apr 20 00:36:50 EDT 2013
Unhandled event loop exception
org.eclipse.swt.SWTError: Item not added
	at org.eclipse.swt.SWT.error(SWT.java:4387)
	at org.eclipse.swt.SWT.error(SWT.java:4276)
	at org.eclipse.swt.SWT.error(SWT.java:4247)
	at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
	at org.eclipse.swt.widgets.ToolBar.createItem(ToolBar.java:392)
	at org.eclipse.swt.widgets.ToolItem.<init>(ToolItem.java:128)
	at org.eclipse.jface.action.ActionContributionItem.fill(ActionContributionItem.java:332)
	at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:353)
	at org.eclipse.ui.internal.ActionSetActionBars.setActive(ActionSetActionBars.java:306)
	at org.eclipse.ui.SubActionBars.activate(SubActionBars.java:151)
	at org.eclipse.ui.SubActionBars.activate(SubActionBars.java:138)
	at org.eclipse.ui.internal.ActionPresentation.setActionSets(ActionPresentation.java:141)
	at org.eclipse.ui.internal.WorkbenchWindow.updateActionSets(WorkbenchWindow.java:1886)
	at org.eclipse.ui.internal.WorkbenchPage$ActionSwitcher.updateActionSets(WorkbenchPage.java:772)
	at org.eclipse.ui.internal.WorkbenchPage$ActionSwitcher.updateActivePart(WorkbenchPage.java:610)
	at org.eclipse.ui.internal.WorkbenchPage$ActionSwitcher.updateTopEditor(WorkbenchPage.java:637)
	at org.eclipse.ui.internal.WorkbenchPage.updateActiveEditorSources(WorkbenchPage.java:348)
	at org.eclipse.ui.internal.WorkbenchPage.updateActivations(WorkbenchPage.java:251)
	at org.eclipse.ui.internal.WorkbenchPage.access$15(WorkbenchPage.java:243)
	at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partActivated(WorkbenchPage.java:172)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$2.run(PartServiceImpl.java:193)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartActivated(PartServiceImpl.java:191)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:596)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:549)
	at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:105)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$1.handleEvent(ContributedPartRenderer.java:61)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
	at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1447)
	at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:2328)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4572)
	at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
	at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
	at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2069)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4989)
	at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
	at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2541)
	at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable.java:80)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4623)
	at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
	at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3129)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3753)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Why is this happening and how can I fix it? If I go back to a single program view at once it seems to work fine, but I really want to see both at the same time.
[Updated on: Sat, 20 April 2013 04:39]
Report message to a moderator
Re: Unhandled loop exception when moving frames around [message #1057974 is a reply to message #1045332] Fri, 10 May 2013 09:17 Go to previous messageGo to next message
yushi nano is currently offline yushi nanoFriend
Hi, I got same error.
I am using Birt and myFace1.1, error happened when I trying to start eclipse.
The eclipse is forced to restarted, please help.
	at org.eclipse.swt.widgets.Tree.createItem(Tree.java:2106)
	at org.eclipse.swt.widgets.TreeItem.<init>(TreeItem.java:203)
	at org.eclipse.swt.widgets.TreeItem.<init>(TreeItem.java:161)
	at org.eclipse.jface.viewers.TreeViewer.createNewRowPart(TreeViewer.java:818)
	at org.eclipse.jface.viewers.TreeViewer.newItem(TreeViewer.java:312)
	at org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem(AbstractTreeViewer.java:847)
	at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer.java:823)
	at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:797)
	at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:644)
	at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:768)
	at org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpand(AbstractTreeViewer.java:1500)
	at org.eclipse.jface.viewers.TreeViewer.handleTreeExpand(TreeViewer.java:952)
	at org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded(AbstractTreeViewer.java:1511)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:132)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
	at org.eclipse.swt.widgets.Tree.wmNotifyChild(Tree.java:7584)
	at org.eclipse.swt.widgets.Control.wmNotify(Control.java:5534)
	at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:1896)
	at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:5086)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4584)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
	at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
	at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:2440)
	at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1534)
	at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5977)
	at org.eclipse.swt.internal.win32.OS.SendMessageW(Native Method)
	at org.eclipse.swt.internal.win32.OS.SendMessage(OS.java:3290)
	at org.eclipse.swt.widgets.Tree.setSelection(Tree.java:4962)
	at org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer.java:353)
	at org.eclipse.jface.viewers.AbstractTreeViewer.setSelectionToWidget(AbstractTreeViewer.java:2544)
	at org.eclipse.jface.viewers.StructuredViewer.setSelectionToWidget(StructuredViewer.java:1767)
	at org.eclipse.jface.viewers.AbstractTreeViewer.setSelectionToWidget(AbstractTreeViewer.java:2970)
	at org.eclipse.jface.viewers.StructuredViewer.setSelection(StructuredViewer.java:1723)
	at org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer.java:1139)
	at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart.showInput(PackageExplorerPart.java:1072)
	at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart.editorActivated(PackageExplorerPart.java:1021)
	at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$1.partActivated(PackageExplorerPart.java:216)
	at org.eclipse.ui.internal.WorkbenchPage$12.run(WorkbenchPage.java:4462)
	at org.eclipse.ui.internal.WorkbenchPage.firePartActivated(WorkbenchPage.java:4460)
	at org.eclipse.ui.internal.WorkbenchPage.access$16(WorkbenchPage.java:4440)
	at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partActivated(WorkbenchPage.java:173)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
My system is:
java.version=1.6.0_17
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_SG
Command-line arguments:  -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.jee.product
This is a continuation of log file C:\workspace\.metadata\.bak_0.log
Created Time: 2013-05-10 16:42:35.178
Re: Unhandled loop exception when moving frames around [message #1392003 is a reply to message #1057974] Tue, 01 July 2014 18:36 Go to previous message
Robert Brodt is currently offline Robert BrodtFriend
Looks like this has already been reported here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=287508
Not sure there's anything we can do here folks, except maybe switch to linux or OS-X?
Previous Topic:Need Help
Next Topic:Can't remove colour scheme from Eclipse Luna
Current Time: Tue May 22 16:02:25 GMT 2018
Powered by FUDForum. Page generated in 0.02939 seconds
