Home » Modeling » TMF (Xtext) » Backslashes as line ending characters
Backslashes as line ending characters [message #1045133] Fri, 19 April 2013 20:44 Go to next message
Brad Riching is currently offline Brad RichingFriend
Greetings Xtext world,
Is it possible to implement a language in Xtext that supports optional backslash line endings? Our legacy language needs to be able to put a backslash anywhere in the file to signal to the external compiler tools that it should continue parsing on the next line. I would eventually like to implement a formatter that adds these backslash line endings to help organize long lines of similar data into a column.
I tried to include a backslash in the whitespace rule, which has the obvious consequence that Xtext does not care if anything comes after the backslash - it's hidden after all. I then thought I could implement a value converter for the whitespace rule and check that only a newline character exists after the backslash, but the corresponding toValue(String string, INode node) method is never called. This is probably because the whitespace rule is hidden.
I need to be able to detect the backslash character and then flag an error or warning in the editor if anything besides a newline occurs after the backslash. Does anyone know if this is possible in Xtext or could offer some advice?
Thanks in advance!
Brad
Re: Backslashes as line ending characters [message #1045599 is a reply to message #1045133] Sat, 20 April 2013 14:30 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
Did you try having only ('\\' '\n') | ('\n') as newline? I.e. only allow
newline or backslash newline as "a newline"?
If you want the newlines to be separate tokens (i.e. backslash newline
is two tokens), or if you accept whites pace between the backslash and
the newline it gets a bit more complicated and you may need to use an
external lexer where you can perform both look ahead and have syntactic
predicates.
- henrik
> Thanks in advance!
> Brad
Re: Backslashes as line ending characters [message #1046939 is a reply to message #1045599] Mon, 22 April 2013 15:19 Go to previous messageGo to next message
Thanks Henrik!
With your help I came up with the following whitespace rule (for windows machines only):
terminal WS:
	(' '|'\t'|'\r'|'\n'| ('\\' (' '|'\t')* '\r' '\n'))+;
Now in my formatter, I would like to be able to add a backslash along with the native line ending characters after some elements of my model. In my case, I have a description of a wiring harness connector, and a list of all of its pins -- all of which are on one line. The list contains comma-separated names and numbers that I would like to appear indented and properly formatted with a backslash line ending sequence after each pin. Essentially I would like to take the entire line and transform it into a column of pins in the connector. Do you know if this is possible with the formatter API that ships with Xtext or if will I need to write my own?
Re: Backslashes as line ending characters [message #1047256 is a reply to message #1046939] Tue, 23 April 2013 01:19 Go to previous messageGo to next message
On 2013-22-04 17:19, Brad Riching wrote:
> Thanks Henrik!
> machines only):
> terminal WS: (' '|'\t'|'\r'|'\n'| ('\\' (' '|'\t')* '\r' '\n'))+;
afaik, you can't use the default formatter to insert anything but
whitespace and linebreaks, so it would need to go into the serializer.
You may be able to combine the serializer with the formatter so that you
only have to deal with this special aspect of serialization and
formatting. One problem is naturally to both have whitespace preserving
rules (you want to keep the inserted whitspace) and formatting at the
same time.
Unless you have a complex language and complicated formatting, the best
option is probably to have the formatting done as part of the serializer
(i.e. always format it the way you want it).
- henrik
Re: Backslashes as line ending characters [message #1047421 is a reply to message #1047256] Tue, 23 April 2013 07:21 Go to previous messageGo to next message
Claudio Heeg is currently offline Claudio HeegFriend
Member
Henrik Lindberg wrote on Tue, 23 April 2013 03:19
c.setSpace("\\\n").after(...)
Or am I missing something here?
Re: Backslashes as line ending characters [message #1047636 is a reply to message #1047421] Tue, 23 April 2013 13:13 Go to previous messageGo to next message
Maybe I did :)
- henrik
Re: Backslashes as line ending characters [message #1049423 is a reply to message #1047636] Thu, 25 April 2013 21:05 Go to previous messageGo to next message
Once again I'm simply amazed with Xtext. Thanks for the help!
Re: Backslashes as line ending characters [message #1745508 is a reply to message #1047421] Tue, 11 October 2016 19:02 Go to previous messageGo to next message
Larry Cousin is currently offline Larry CousinFriend
I know this was three years ago that this thread was being discussed, but I am also interested in being able to correctly process with Xtext "\" at the end of a line like the C pre-processor does. I am novice to Xtext and I don't understand what:
does or where it should be placed. The serializer is mentioned, but when I look at the files in my Xtext language serializer folder (2.10), I don't see any code similar to this.
Could someone explain to me the neophyte what this setSpace does and where it could be placed?
Larry
Re: Backslashes as line ending characters [message #1745509 is a reply to message #1745508] Tue, 11 October 2016 19:27 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
Can you elaborate on what you want to actually want to do
The code mentioned Obote goes to the (old) formatter (1) code
To get stuff for the serializer generated you need to configure the workflow
Sth like (serializer={generatextendstub=true})
So still the question is this about parsing or about serialist ion/formatting
Need professional support for Xtext, Xpand, EMF?
Go to: https://xtext.itemis.com
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Previous Topic:Thank you!
Next Topic:Strange Serialization
Current Time: Sun Jun 24 22:59:27 GMT 2018
Powered by FUDForum. Page generated in 0.02591 seconds
