Home » Modeling » TMF (Xtext) » Error with own editor opener
Error with own editor opener [message #1045045] Fri, 19 April 2013 17:38 Go to next message
Stefano Cottafavi is currently offline Stefano CottafaviFriend
Member
I'm developing a plugin on/for Eclipse 4.2, Xtext 2.4 and I would like to bind my own editor opener.
In the UIModule I added the following lines
public void configureLanguageSpecificURIEditorOpener(Binder binder) {
  if (PlatformUI.isWorkbenchRunning())
    binder.bind(IURIEditorOpener.class)
    .annotatedWith(LanguageSpecific.class)
    .to(FastfstEditorOpener.class);
Unfortunately I get some error messages (more like the following one).
Am I missing something? Thank you
Stefano
!ENTRY org.apache.log4j 4 0 2013-04-19 01:03:04.180
!MESSAGE sc.ndt.editor.fast.ui.internal.FastfstActivator  - Failed to create injector for sc.ndt.editor.fast.Fastfst
103  [main] ERROR sc.ndt.editor.fast.ui.internal.FastfstActivator  - Guice creation errors:
1) No implementation for sc.ndt.editor.fast.ui.addon.hyperlinking.FastfstEditorOpener was bound.
  at sc.ndt.editor.fast.ui.FastfstUiModule.configureLanguageSpecificURIEditorOpener(FastfstUiModule.java:82)
1 error
com.google.inject.CreationException: Guice creation errors:
1 error
	at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:435)
	at com.google.inject.internal.InternalInjectorCreator.initializeStatically(InternalInjectorCreator.java:154)
	at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:106)
	at com.google.inject.Guice.createInjector(Guice.java:95)
	at com.google.inject.Guice.createInjector(Guice.java:72)
	at com.google.inject.Guice.createInjector(Guice.java:62)
	at sc.ndt.editor.fast.ui.internal.FastfstActivator.createInjector(FastfstActivator.java:67)
	at sc.ndt.editor.fast.ui.internal.FastfstActivator.getInjector(FastfstActivator.java:55)
	at sc.ndt.editor.fast.ui.FastfstExecutableExtensionFactory.getInjector(FastfstExecutableExtensionFactory.java:26)
	at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:49)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:262)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
	at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:273)
	at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:269)
	at org.eclipse.ui.internal.registry.EditorDescriptor.createEditor(EditorDescriptor.java:235)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:319)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:262)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPart(CompatibilityEditor.java:61)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:299)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:861)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:841)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:113)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:321)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:242)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:894)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:629)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:731)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:702)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:696)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:681)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1115)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:98)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:645)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:59)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:641)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:520)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:505)
	at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:74)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:644)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:987)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Re: Error with own editor opener [message #1045055 is a reply to message #1045045] Fri, 19 April 2013 17:53 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
HI,
i cannot reproduce this. how does the opener look like?
Need professional support for Xtext, Xpand, EMF?
Go to: https://xtext.itemis.com
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Re: Error with own editor opener [message #1045194 is a reply to message #1045055] Fri, 19 April 2013 22:58 Go to previous messageGo to next message
Member
Hi Christian,
thank you for looking into this. The opener goes like
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EReference;
import org.eclipse.ui.IEditorPart;
import org.eclipse.xtext.ui.editor.LanguageSpecificURIEditorOpener;
public abstract class FastfstEditorOpener extends LanguageSpecificURIEditorOpener {
	public IEditorPart open(URI uri, EReference crossReference, int indexInList, boolean select) {
		return super.open(uri, crossReference, indexInList, select);
cheers
Re: Error with own editor opener [message #1045403 is a reply to message #1045194] Sat, 20 April 2013 07:19 Go to previous messageGo to next message
Amm this class is abstract
Re: Error with own editor opener [message #1045412 is a reply to message #1045403] Sat, 20 April 2013 07:37 Go to previous message
Member
Thank you.
my bad (I will stop to code late at night!), removing abstract it works fine.
Smile
ste
Previous Topic:Two questions with regards to plantuml?
Next Topic:Creating functions with named arguments
Current Time: Mon May 21 23:00:14 GMT 2018
Powered by FUDForum. Page generated in 0.02104 seconds
