Home » Eclipse Projects » BPMN 2.0 Modeler » Simulation in BPMN2.0 modeler
Simulation in BPMN2.0 modeler [message #1012494] Thu, 21 February 2013 11:58 Go to next message
Hassan BAZOUN is currently offline Hassan BAZOUN
Member
I found out that the "Simulation and debug support of business processes" is included within the scope of the BPMN2.0 modeler.
Is this feature implemented in the latest release of the Modeler? If not are you intending to imlement it? If yes do you have any resource on how i can simulate a business process using the modeler.
I found that there exists a tab "Simulation" the BPMN diagrams but i can't figure out how we can run the simulation after entering the input values. I searched for documentation on this subject but i found nothing.
This is very important since i need to figure out it exists or i am obliger to code it Smile.
Thanks in advance.
Hassan
Re: Simulation in BPMN2.0 modeler [message #1012506 is a reply to message #1012494] Thu, 21 February 2013 12:24 Go to previous messageGo to next message
Robert Brodt is currently offline Robert Brodt
Hi Hassan,
Currently the "Simulation" tab is only there for compatibility and to allow you to edit those properties for the jbpm5 runtime. Simulation of a process is not yet possible from the eclipse BPMN2 Modeler, but it IS available with the jBPM Web Designer so we wanted to provide support for this in the eclipse editor as early as possible.
Note that the jBPM Web Designer implements a subset of the newly emerging Business Process Simulation standard that is being defined by the bpswg. You may have a different concept of what "simulation" means, e.g. tracing a running business process which, IMHO, falls more into the BAM category.
Tracing and simulation are features that are in the project plan for the BPMN2 Modeler, unfortunately I haven't had much time to devote to this. If you DO decide to to look into coding this new functionality, please let me know and I'll be happy to answer any questions you might have Wink
Cheers!
Bob
Re: Simulation in BPMN2.0 modeler [message #1012514 is a reply to message #1012506] Thu, 21 February 2013 12:31 Go to previous messageGo to next message
Member
Thanks Bob for your quick reply.
i think you will recieve a lot of questions in the coming few months Razz
Cheers
Hassan
Re: Simulation in BPMN2.0 modeler [message #1012545 is a reply to message #1012514] Thu, 21 February 2013 14:13 Go to previous message
Bring it on!!! Very Happy
Previous Topic:Release 0.2.3 now available
Next Topic:bpmn2 diagram editor refresh
Current Time: Sun May 19 23:59:27 EDT 2013
Powered by FUDForum. Page generated in 0.04096 seconds
